ahe Posted August 22, 2021 Report Posted August 22, 2021 (edited) Fuselage etc Mooney M20A (Wood wing) airplane crashed in field - for display use The parts available from the plane is the whole fuselage and engine (no instruments). The accident happened due to fuel starvation and the landing had been successful if the field was a bit longer. The accident caused damage to the wing where the right wheel is attached. The complete tail-part is not damaged together with the cabin and wing control surfaces. The retractable undercarriage system only suffered minor damage, mainly the control-bars to the right main wheel. Please see attached pictures For display use or similar Price for plane EURO 600. Lycoming Engine - O-360-A1A Complete with all accessories, carburetter, fuel pump, magnetos, governor, vac pump etc. Engine from a parted out Mooney M20A aircraft that was damaged after landing in field 11/7 2015 due to fuel starvation. Engine needs shock load inspection or used for parts TTSN 3000 hours Overhauled cylinders and many other parts at 2000 hours. Including engine handbook Lycoming O-360-A1A S/N L-1844-36 EUR 1.500 or best offer Propeller Propeller McCauley 2D36C14-FGS78KM-4 S/N 757183 Removed from parted out Mooney M20A Aircraft that was damaged after landing in field One intact blade. Needs OH Make an offer Location - Denmark. Contact info helms.adam@gmail.com +45 29 99 12 02 Edited October 4, 2021 by ahe Engine now solt, price on rest Quote
