2 hours ago, robert7467 said:
Does anyone have a diagram for the wing leveler?
Thanks!
They are in the downloads tab.
I saw those, but it's not the full diagram. Really need to know about the hoses that go into the little valve and how it connects to thing that sits at the 45 degree angle and how it all ties in together to the vacuum source. The guy that was assisting my with my panel upgrade basically disabled it and pulled all the hoses from those 2 components. I can figure out the yoke hoses from the diagram in downloads, but how does it all tie in together. Luckily all the servo lines on the bottom of the 45 degree thingy are still in tact. It's just source and tieing those two components together.
Actually it helps a little, there are still 2 hose nipples on the TC. Also the permanently capped nipple I believe is where my PC adjustment knob went that's mounted on the center of the yoke. I will take some pics of the items in question.
I think the avionics guy and I might have this figured out. We are going to vacuum test it tomorrow. Thank you guys for your help!
