rainman Posted July 24, 2020 Report Posted July 24, 2020 I just received a GoPro Hero 8 Black. I know I’ll need the cables for intercom/ATC audio in, and I’ve found that on the internet. Does the propeller filter used on the GoPro 7 also work on the GoPro 8? I’m looking forward to recording some flights in my Mooney as well as my gyroplane (pusher prop, no filter needed). Ray Quote
gsxrpilot Posted July 24, 2020 Report Posted July 24, 2020 I believe you can take the prop out of the picture with internal settings on the Hero8 or in post processing. I've got a couple of them so I'll take a look to be sure. Quote
rainman Posted July 24, 2020 Author Report Posted July 24, 2020 Thanks Paul. The GoPro support forum says that you can’t fix prop distortion in settings on the Hero 8. The NFlight filter specifically lists the GoPros 5,6,&7, but not the 8? Ray Quote
gsxrpilot Posted July 24, 2020 Report Posted July 24, 2020 3 hours ago, rainman said: Thanks Paul. The GoPro support forum says that you can’t fix prop distortion in settings on the Hero 8. The NFlight filter specifically lists the GoPros 5,6,&7, but not the 8? Ray All you need is a Neutral Density filter. There are lots of them for sale on Amazon from various places, specifically for the Hero8. Any neutral density filter will work. 1 Quote
