alun Posted April 21, 2009 Report Posted April 21, 2009 hi guys, i had an edm930 installed recently. now i have a problem with the left tank reading. it has been fine for about 2 months, now when i turn the engine on, i get a reading that is correct but it then drops away slowly over the next half an hour to zero. next time i turn i fly it starts of correctly again, then the slow fall off to empty. has anyone else ever had a guage that did this? i am wandering if it is a fault on the sender or the edm (i suspect its the edm as why would it read correctly at the beginning and then drop??). al.
