I just put an EDM 900, Garmin G5 and CiES senders in my 1966 M20E and I have some extra parts leftover that I'm selling. The prices include ground shipping within the USA from Huntsville AL area.
***SOLD***EI UBG-16
***SOLD***EI FP-5L
***SOLD***Garwin Cluster Gauges P/N 22-169-07-A $300- Cluster gauges with harness. Oil temp probe, CHT probe, shunt and original fuel float senders available on request as well. The fuel levels were jumpy in some positions, but unknown if it was sender or gauge. Otherwise the cluster gauge worked fine when removed.
Misc parts - Now asking $200 for all of them together:
*Mitchell Tachometer P/N D1-112-5025 - Tach worked fine when removed. Can include tach cable if needed.
*Manifold Pressure / Fuel Pressure gauge P/N22-469-01-A - Worked fine when removed.
*Attitude Gyro P/N 23-501-06 - Tumbles and needs O/H.
*Brittain Pilot Valves - 2 Brittain pilot valves. Unknown condition.
Here are some pictures:
Edited by Frozen Flying
Sold UBG-16 and FP-5L
  On 12/1/2017 at 5:28 PM, Frozen Flying said:
I just put an EDM 900, Garmin G5 and CiES senders in my 1966 M20E and I have some extra parts leftover that I'm selling. The prices include ground shipping within the USA from Huntsville AL area.   EI UBG-16 S/N 099628 $500- Engine monitor with harness, 4 EGT probes, 3 CHT bayonet probes (4th CHT probe needs to be replaced since it was broken during spark plug removal.) Engine monitor has a hazy display when powered down, but looks fine when turned on. Everything worked when removed.   EI FP-5L S/N 100944 $400- Fuel totalizer with harness and fuel flow sensor. Worked fine when removed.   Garwin Cluster Gauges P/N 22-169-07-A $300- Cluster gauges with harness. Oil temp probe, CHT probe, shunt and original fuel float senders available on request as well. The fuel levels were jumpy in some positions, but unknown if it was sender or gauge. Otherwise the cluster gauge worked fine when removed.   Mitchell Tachometer P/N D1-112-5025 $100- Tach worked fine when removed. Can include tach cable if needed.   Manifold Pressure / Fuel Pressure gauge P/N22-469-01-A $200- Worked fine when removed.   Attitude Gyro P/N 23-501-06 $50- Tumbles and needs O/H.   Brittain Pilot Valves $50- 2 Brittain pilot valves. Unknown condition. $50 for both. IMG_0347.jpg.7ef4f3ef23c7d666ba254ee8e8107cb2.jpg
  On 12/2/2017 at 6:04 AM, N5937Q said:
Sent from my iPad using Tapatalk[/quote
I have a M20C myself, putting in an edm 900 also. Would like to talk with you about your upgrades sometime. I live in Huntsville, but plane is at 8A1., Thanks John
Expand
Expand
I sent you PM
