20 hours ago, bonal said:
I suppose it also has a bit to do with what your leaving to the elements. Big difference between a 30 to 40k 20c compared to a 200k plus Ovaion or Acclaim. Even though worth much less fiscally my D/C is priceless to us so am very happy it's indoors.
its kind of weird at K1o2 there are no hangars on airport property all are on adjoining private property so FAA regs on What's in them aren't enforced and may not apply. There is going to be some security fences installed and the county is working with the private owners to make sure they are not cut off from the field.
I thought the FAA only allowed "through the fence" operations for residential property.
After taking my back seat out and looking behind the panels, I see a jillion possible scenarios where water can get into a plane unseen for years.  If you do an outside tie down, I would strongly recommend a good cover.
