cnoe Posted July 15, 2016 Report Posted July 15, 2016 FWIW in my experience the ball-end type hex keys sometimes don't work as well as a regular one (in many hex screws or socket-head bolts). I prefer the ball-end types only when necessary for clearance. This may or may not have any bearing on your issue. Sent from my iPad using Tapatalk
Guest Posted July 15, 2016 Report Posted July 15, 2016 6 hours ago, Patto said: It's the KLX135 that I am trying to remove (I previously said the 155, which was wrong). I pulled and pulled, but the deck never actually came loose, so something was wrong to begin with. I imagine that I will have to take it to an avionics shop and pay them to remove it. It's under warranty from work that was done in March, but that outfit is in California and I'm in Oregon. Would be a fun excuse for a cross-country trip to just fly it down there though... From the picture it looks like you have the 135 backed out, it's possible that the lock is caught on the AtT50 transponder. Perhaps removing the transponder may release the 135. To remove the transponder I think you'll need a 5/64 Allen wrench. Narco used a different size than other manufacturers. Clarence
N601RX Posted July 15, 2016 Report Posted July 15, 2016 Remove the radio above and below it. You should then be able to get enough clearance between the case and radio to push the locking arm back down even if the screw is broken or stripped.
Patto Posted July 25, 2016 Author Report Posted July 25, 2016 I'm headed up to Pacific Coast Avionics this Friday to get some help with it. The compass needs to be looked at anyway, so we'll do both at once. I may get his opinion on what kind of upgrades might by worth doing in my limited budget.
Pictreed Posted July 27, 2016 Report Posted July 27, 2016 They're the ones that sold me all the Avidyne gear so be careful. Lol
Patto Posted July 30, 2016 Author Report Posted July 30, 2016 On 7/15/2016 at 3:40 AM, M20Doc said: From the picture it looks like you have the 135 backed out, it's possible that the lock is caught on the AtT50 transponder. Perhaps removing the transponder may release the 135. To remove the transponder I think you'll need a 5/64 Allen wrench. Narco used a different size than other manufacturers. Clarence Clarence, you were right. It was caught on the transponder. It's out now and will be shipped out for service since it's under warranty.
