My C had a couple to pick from (shaft length) depending on location.
Do you know which one you are looking for?
I need to hunt a few fasteners as well. It will be in a couple of days though...
The battery access panels seem to shed a couple every decade or so...
The camlocs between the upper and lower cowling are 40S5-4S
The screws in the front corner and in the air inlet are MS24694S51
Along the lower cowl to firewall are 40S5-2S
Around the Induction air duct 27S3-3S
Around the exhaust are 27S3-3S
NOTE:
2. Length of camloc may vary +/- 2 sizes depending on composite layers. Use proper length for attachment.
