(First time lurker posting after recently bought my first M20C)
The trim switch recently became stiff to toggle and got stuck. Took some time to took it off and disassembled it.
Turns out the 2 toggle switches are 7105 C&K SPDT switches. 7105P4D9ZQE is the exact fit but it's not available on Mouser/Digikey. 7105P4YZQE is the next close enough switch that are in stock and can be shipped immediately! Eagerly waiting for it to arrive :)
This is the datasheet for anyone who likes to learn more.
On the disassemble process, attached some images with some key components, the 4 small screws can be removed using T5 screwdriver.
Figured I'd share this info for anyone who'd like to avoid buying the entire expensive switch! Cheers
Nicholas
  • Thanks 2
