Selling used alternator setup removed from m20C O360 wide deck.  It was working when removed Oct 2016.  Replaced it because CB had tripped twice in two months or so.  Finally found the issue when it was all being removed, there was an unshielded ground wire under panel that sometimes vibrated over and caused a short.  Was not the fault of any of the parts, but had already purchased replacement system so installed it.
InterAV PN 015-01237  12v. 50 amps SN 625-61623 new 9-1996.
IRAN by interAv 1-16-2008, had new brushes installed and a new regulator SN 14125 purchased.  Has 300 hours since then, about 1100 TT on it. Comes with manual and over voltage parts has mounting brackets, apparently a narrow deck bracket adapted to mount on wide deck engine.  Asking $500 OBO. Baffle rubbed on case so rubbed part of label off.
