As has been alluded, the restriction that drives the flow rate is inside the injector nozzle.   As long as the lines leading up to that are significantly larger and unrestricted, sufficient that the pressure drop across that line is negligible, then all of the pressure drop will be across the nozzle and the system will work as intended.
FUEL INJECTION SYSTEMS - Overhauls and Exchanges
