Oh! That is very helpful info, Anthony! I'll pursue that theory, in the hopes that a simple repair or replacement will work. Thanks!
No problem....it may even be as as simple as cleaning the connectors at the KG102...maybe try that first
In a lot of cases the four shock mounts on the KG 102 are shot, leading to premature gyro failure.
Yes you're right Doc..,mine were a bit worn so o replaced them at the same time....Castleberry provided a set (on my request) with the exchange core
