Lycoming tear down inspection shop recommendation
On 9/18/2022 at 9:04 AM, LANCECASPER said:
One major advantage of using the shop your A & P recommended is expectation bias. He expects a good result so isn't likely to put any blame on the shop he chose. He is likely to go above and beyond to make it work to prove his point.
If you use a different shop, especially far away, any problems that come up will tend to be blamed on not using the shop he told you to use.  You will find a bad review on any shop out there - you can't please all of the people all of the time. The fact that the collective braintrust of Mooneyspace only remembers only bad review says quite a bit.
Well, I can't even get Western Skyways to call me back.  So...
