1 hour ago, nosky2high said:
Can this be mounted on the belly?  Is there enough clearance to flare?
I just measured the vertical length which is what you would be concerned with (not diagonal tip to base) and the length is 13.25 inches from the bottom of the mount to the lowest point of the Antenna. The tip to base diagonal measurement is 17 inches but it is angled back so the 13.25 should be what you would need.
