Problem solved!! With the help of John B, I called and got ahold of Lonnie in the Avionics shop at LASAR. He said that there is a Pico Fuse (1/4 amp)  that goes bad on these circuits and needs to be replaced. It is wired into the circuit board. They send them out to an electronics shop to be repaired. I ordered 10 pico fuses from Mouser and had a radio shop replace one in 10 minutes and the problem is solved on my trim indicator. It is the same fuse that goes bad on the Trim, Flaps, Co
    • Like
    3
