Fellow Mooniacs,
The Stall Switch of our 1998 M20J Allegro is being stuck because of some bug or dust that got inside the system. If I spray some lubrification it momentary solves the problem, but after 30mins it’s again stuck and somehow “glued” to something...
I already tried to apply silicone spray, contact cleaner, etc, and nothing is solving the problem. Til now, normal WD40 was the best result since it improved the switch movement a bit more than the other options I tried...
