My Taxi Light stopped working and seems to have a marginal contact in the Positronic connector in the circuit breaker box.  I found the attached service bulletin describing the issue.  Has anyone installed this kit on their planes and was was the failure mode?  I measure 24 volts at the Taxi light switch and it drops to .1 volts as soon as the switch is turned on. Driver M20-286--Landing and Taxi Light.pdf
