Marauder Posted September 2, 2013 Report Share Posted September 2, 2013 Can you post a picture of your front mount? That is the one that will get me into the hangar Quote Link to comment Share on other sites More sharing options...
rainman Posted September 3, 2013 Report Share Posted September 3, 2013 This is the front mount. Hope this helps. A distant view of the whole thing is in my gallery but I don't know how to show it here. Ray Quote Link to comment Share on other sites More sharing options...
rainman Posted September 3, 2013 Report Share Posted September 3, 2013 O.K. So I don't know too much about photography, but I think this will give you the distant view of the tow-mower set-up. Hope this helps. Ray Quote Link to comment Share on other sites More sharing options...
Marauder Posted September 3, 2013 Report Share Posted September 3, 2013 Thank you! (My back thanks you as well). I think I have everything I need to put the project together. Will post some pictures when I have it done. Thanks again. Quote Link to comment Share on other sites More sharing options...
rainman Posted September 3, 2013 Report Share Posted September 3, 2013 Just ralized the picture is terrible. Just took another, should be better. Ray 1 Quote Link to comment Share on other sites More sharing options...
toomanyswitches Posted July 25, 2014 Report Share Posted July 25, 2014 Hi guys As I am new to mooneys and read this thread I was wondering if you cold give me some expert advice. I am winching my mooney into my hangar a per picture below. Can any damage be done with the sling I have hooked around the nose gear in the position on the pic? This is where the tow bar hooks anyway? Thanks Quote Link to comment Share on other sites More sharing options...
Marauder Posted July 25, 2014 Report Share Posted July 25, 2014 Hi guys As I am new to mooneys and read this thread I was wondering if you cold give me some expert advice. I am winching my mooney into my hangar a per picture below. Can any damage be done with the sling I have hooked around the nose gear in the position on the pic? This is where the tow bar hooks anyway? Thanks You'll be fine. Where the damage usually occurs is when someone turns the plane too far right or left when towing and dents the nose truss. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
orionflt Posted July 25, 2014 Report Share Posted July 25, 2014 You'll be fine. Where the damage usually occurs is when someone turns the plane too far right or left when towing and dents the nose truss. Sent from my iPad using Tapatalk Hi guys As I am new to mooneys and read this thread I was wondering if you cold give me some expert advice. I am winching my mooney into my hangar a per picture below. Can any damage be done with the sling I have hooked around the nose gear in the position on the pic? This is where the tow bar hooks anyway? Thanks at first I thought you meant you were towing it in backwards but pulling from the nose..... now that would not be a good thing but what your doing is fine Brian Quote Link to comment Share on other sites More sharing options...
toomanyswitches Posted July 25, 2014 Report Share Posted July 25, 2014 Thanks for the reply Quote Link to comment Share on other sites More sharing options...
butchgilbert Posted July 26, 2014 Report Share Posted July 26, 2014 +1 Sidewinder, portable, foldable, but not cheap. Butch Quote Link to comment Share on other sites More sharing options...
Nemesis Posted July 27, 2014 Report Share Posted July 27, 2014 Hi guys As I am new to mooneys and read this thread I was wondering if you cold give me some expert advice. I am winching my mooney into my hangar a per picture below. Can any damage be done with the sling I have hooked around the nose gear in the position on the pic? This is where the tow bar hooks anyway? Thanks I also can not imagine much of a problem towing forward using the tow bar hole... except, are you using rope or steel cable? In the photo it sort of looks like that cotton rope with a red stripe on it. The only thing that I would worry about is if it is rope and the rope breaks, you might have one heck of a runaway problem. I would hate to see your tail damaged or something worse. Dave Quote Link to comment Share on other sites More sharing options...
