joegoersch Posted February 18, 2013 Report Share Posted February 18, 2013 I'm going to try to get my CFI in my M20J. I'm starting to practice maneuvers , specifically Steep Turns, Steep Spirals, Lazy Eights, Chandelles, Eights on Pylons, and Slow Flight (clean and dirty). Can anyone suggest, as a starting point, power (prop setting and manifold pressure) that works well for these maneuvers ? Thanks! Quote Link to comment Share on other sites More sharing options...
Hank Posted February 18, 2013 Report Share Posted February 18, 2013 I do my maneuvers at or below Va. Pick something comfortable in that range. What do you use for an approach? Try that as a starter. For my C, it's typically 2300 and 20" or less when playing at 3000' msl; yours will be different. For instance, top of the white arc is 2300/19" clean, and I reduce to about 16" to slow to 90 knots; drop Approach flaps and I'm back to 19"; drop gear and I'm descending in a very ILS-like manner. Quote Link to comment Share on other sites More sharing options...
Parker_Woodruff Posted February 18, 2013 Report Share Posted February 18, 2013 I'm going to try to get my CFI in my M20J. I'm starting to practice maneuvers , specifically Steep Turns, Steep Spirals, Lazy Eights, Chandelles, Eights on Pylons, and Slow Flight (clean and dirty). Can anyone suggest, as a starting point, power (prop setting and manifold pressure) that works well for these maneuvers ? Thanks! Steep turns: Remember, you need to be below Va for your given weight. I don't know how much your plane weighs and its limits. IIRC, I used about 18" and 2500 RPM which yielded me about 110-115 KIAS when heavy. But it's been awhile and I haven't taught the commercial maneuvers in an M20J in awhile. Steep spirals are going to be done with the power off, so just use a really low power setting so you can decelerate to speeds appropriate for landing gear extension. Every airframe is different. You need to just go up alone and climb to an altitude you plan to maneuver at for your local flying. Then figure out what kind of power reductions it takes to slow down in an efficient way. Figure out what power settings give you the speeds you need. Quote Link to comment Share on other sites More sharing options...
John Pleisse Posted February 18, 2013 Report Share Posted February 18, 2013 Va here, also. In my 79 201 it is 13"/2400 rpm, 105 KIAS. Works great for all the commercial maneuvers. 1 Quote Link to comment Share on other sites More sharing options...
joegoersch Posted February 19, 2013 Author Report Share Posted February 19, 2013 Va here, also. In my 79 201 it is 13"/2400 rpm, 105 KIAS. Works great for all the commercial maneuvers. That's about what I got when I flew earlier tonight. Wow, not much power to fly slow in a J ! Quote Link to comment Share on other sites More sharing options...
