I had an in flight servo failure with the Garmin GFC500 autopilot and I had to pay $2500 out of pocket. I am wondering if you can share your experience with your replacement on your mooney. The stated hours for the routine repair were quoted at 4-6 hours when I dropped the plane off but the install on the bill is 19.4 hours. The dealer also enabled smart glide when the plane was not equipped with a GAD 13 so this resulted in an error when I took off.
I am looking for a shop in Southern California that can install a GAD 13 and inspect the installation done by this shop as I am not confident in their work. Any recommendations?
I emailed Garmin support but have not got a response yet. Attaching the receipt.
N3486NSB23024.pdf
Item 1 is for the Remove and replace for 2 servos.   4 hours each does not seem completely out of line
Item 2 charging you a day for waiting on Garmin Tech supports seems out of line.   Pretty sure the tech was not waiting by the phone and was able to bill to other jobs.
Item 3 upgrade seems in line.    but missing that you did not have the GAD13 install should have shown up on a check out and they should have resolved before return to service.   Worth a question, but not a major talking point.
From personal experience (working at a Garmin dealer shop) I normally expect around 8 hours per servo for removal and installation of a GSA28. Yep, they are a pain to do the job properly.
Agree with Yetti that 8 hours for Line 2 seems a bit out of line but as a maintenance inspector myself, I will say trying to troubleshoot stuff  on GA aircraft is extremely open-ended and the time spent can balloon very quickly. Not defending the figure in the invoice but maybe there's more to the story than what's written on the paper. I do my best to document every detail so I can defend myself if a customer questions the billable hours.
Socal ... try David Nutile with Helicomm Avionics. Good guy.
Thanks I agree. To clarify this was a warranty repair for Garmin's faulty autopilot servos.
I am wondering if people typically come out of pocket for Garmin warranty claims. I can't get a reply from Garmin support.
Thanks. When you do warranty work on the GSA28 servos can you petition Garmin to cover the extra hours required?
I don't think I can reasonably question line #2 without knowing all that was involved. I am fine paying for that.
Certainly not disputing your experience but when I had my 4 servos replaced under warranty they were completed in 16 hours.  I don't know if some servos were quicker than others but that is an average of 4 hours.  I'm sure it varies by aircraft and whether the shop did the original install and a host of other things.
I took my plane to Crown Avionics at KPAE which installed the GFC 500 originally and Matt replaced all three servos under warranty at no charge.
I had a previous response but I realize I was thinking *new* servo installations instead of remove+replace all this time. Certified "oops" moment. New servo installs take 8+hours because of the extensive sheet metal work involved with installing the brackets and framework.
I admit I don't have any experience with Garmin A/P on Mooneys (maybe soon when we consider replacing the S-Tec 60-2 on the 201 I fly, but that's a topic for later) but from my experience doing a 4-servo replacement on a Bonanza, it took me two days so it's squarely aligned with your experience. But I can see this taking longer on some real painful types like the T-tail Arrows and Skylane RGs (gotta crawl way into the tail to access the pitch servos).
Garmin reimburses up to 2.5 hours per servo per their Service Life Extension Program. I don't handle the financials at my place so not sure how we do it but I wager most shops would charge just the difference within a reasonable range (e.g. 4 - 2.5 = 1.5 hours/servo as shown in the example above).
I don't think shops are really in a position to negotiate with Garmin to cover extra hours, but if the extra hours were caused by an egregious error or oversight by the original installer, then I know Garmin has a pretty hardline policy of requiring the responsible installer to make right on the issues on their own dime (or at least pay for it).
Thanks! I asked Garmin for reimbursement or some other form of goodwill for the additional hours. They will probably say no but it doesn't hurt to ask :D
I may have missed this, but was this the shop that originally installed your GFC500?
FWIW.  I had my GFC500 servos replaced (4 servos including YD) under warranty and my shop didn't invoice me for the work.  But that was a just a simple servo exchange...
...then that might have added hours to troubleshoot and fix.  But should be a discussion with the shop as to what they found and why the overage I would think.
