Thoughts on 6-9 month engine preservation
schule
Mark, I would follow the recommendations to preserve the engine with preservative oil and dessicant plugs but with an extra bit.  Fill the engine with Philips Aviation Anti-rust oil until it runs out of the breather tube and fill the cylinders level full as well.
Link to comment
Share on other sites
The dessicant plugs are a good idea. Also find a dessicant bag for the exhaust pipe. One or more valves will be open so you have outside air getting into the engine. I have heard of people leaving a low wattage light bulb on inside the cowl to drive out moist air. That may not be the safest thing to do if it's not going to be monitored at all.
Link to comment
You may also want to make a deal to have someone fly it on a periodic basis during that timeframe.  Other components also have issues when left alone and not exercised for a period of 6-9 months.   Maybe someone you trust to operate the aircraft?  Bring on a short term partner for a period of time that you can have leave the arrangement upon return or a letter at any time?
-Seth
Link to comment
