Echo Posted Thursday at 01:54 AM Report Posted Thursday at 01:54 AM So, anybody had there Dukes Motor worked on? I heard a company in California USED to do them, but that is no longer available. What is process for those that have recently completed?
Fritz1 Posted Thursday at 06:04 PM Report Posted Thursday at 06:04 PM call Maxwell and Lasar on Monday and see what they say, check BAS salvage and a couple MSCs to see if they have a motor or an actuator sitting around, I keep fingers crossed!
kortopates Posted Thursday at 10:42 PM Report Posted Thursday at 10:42 PM A new motor is/was $25K. I know someone that bought one not long ago when there were only 4 left.Sent from my iPhone using Tapatalk
PT20J Posted 23 hours ago Report Posted 23 hours ago Is this a motor for a gear actuator or a fuel pump? Aeromotors lists capability for Dukes fuel pumps but not actuators. Wouldn't hurt to call. Do you know what is wrong with the motor? 1 1
PT20J Posted 23 hours ago Report Posted 23 hours ago 1 hour ago, kortopates said: A new motor is/was $25K. I know someone that bought one not long ago when there were only 4 left. Sent from my iPhone using Tapatalk Where did he source it, Paul?
kortopates Posted 23 hours ago Report Posted 23 hours ago Where did he source it, Paul?The factory.Sent from my iPhone using Tapatalk 1
201Steve Posted 22 hours ago Report Posted 22 hours ago I don’t understand why there isn’t tribal knowledge about an alternative option from the former California shop. It’s just a basic motor. There are thousands of motors across airframes and would assume they are typically refurbished with off the shelf parts. Are there no more electric motor shops in America? Is it more complicated than I assume? 2
1980Mooney Posted 18 hours ago Report Posted 18 hours ago (edited) 6 hours ago, Bartman said: Aeromotors LLC Products - Aeromotors As @PT20J says, the list has lots of Dukes fuel pumps but no Dukes actuator motors for some reason. After you open the link above, click on this: https://aeromotorsllc.com/home/products?type=actuator Edited 18 hours ago by 1980Mooney
1980Mooney Posted 18 hours ago Report Posted 18 hours ago Dodson "might" have a salvage actuator. I say might because it is missing the last 2 numbers of 4196-00-10.
PT20J Posted 6 hours ago Report Posted 6 hours ago 16 hours ago, kortopates said: The factory. Sent from my iPhone using Tapatalk Was that for just the motor, or an entire landing gear actuator?
Echo Posted 6 hours ago Author Report Posted 6 hours ago 16 hours ago, PT20J said: Is this a motor for a gear actuator or a fuel pump? Aeromotors lists capability for Dukes fuel pumps but not actuators. Wouldn't hurt to call. Do you know what is wrong with the motor? Thank you. My question was regarding a gear actuator motor. $25k? Impressive number. 1/4 the value of my plane. No thanks. Interesting replies. I would agree that this is just a motor and replacement of brushes should not be difficult for an entity that does overhaul repair work. Sourcing proper brushes may prove challenging. The brushes are unique in that the contacts are on opposite side of the majority of brushes currently manufactured. Old Briggs and Stratton lawn mower may be your friend...
Matthew P Posted 6 hours ago Report Posted 6 hours ago Call https://www.aerofluidproducts.com/ they bought out Dukes in 2018, they may be able to provide some insight
Echo Posted 6 hours ago Author Report Posted 6 hours ago 6 minutes ago, Matthew P said: Call https://www.aerofluidproducts.com/ they bought out Dukes in 2018, they may be able to provide some insight thanks. I am good. I just wondered what everyone else is doing.
EricJ Posted 4 hours ago Report Posted 4 hours ago 1 hour ago, Echo said: thanks. I am good. I just wondered what everyone else is doing. If it's just the motor, you can take it to any electric motor shop willing to work on it. An A&P just needs to "supervise", which isn't really defined anywhere. 1
kortopates Posted 3 hours ago Report Posted 3 hours ago Was that for just the motor, or an entire landing gear actuator?New production gear actuators that didn’t get used.Sent from my iPhone using Tapatalk 1
