Mcstealth Posted July 18, 2012 Report Posted July 18, 2012 How do you look up damage history? N5953Q is the Mooney in question. FAA REGISTRY N-Number Inquiry Results N5953Q is Assigned Data Updated each Federal Working Day at Midnight Aircraft Description Serial Number 3193 Type Registration Individual Manufacturer Name MOONEY Certificate Issue Date 04/04/2012 Model M20C Expiration Date 04/30/2015 Type Aircraft Fixed Wing Single-Engine Status Valid Pending Number Change None Type Engine Reciprocating Date Change Authorized None Dealer No MFR Year 1965 Mode S Code 51731312 Fractional Owner NO Quote
jetdriven Posted July 18, 2012 Report Posted July 18, 2012 ntsb accident query, start there, then look at reports.myairplane.com Quote
gregwatts Posted July 18, 2012 Report Posted July 18, 2012 http://www.ntsb.gov/aviationquery/brief.aspx?ev_id=62434&key=0 Quote
Mcstealth Posted July 18, 2012 Author Report Posted July 18, 2012 So if I am reading that correctly, in late 1971 with 1500 hours, the gear collapsed because of running off into the grass/mud/dirt, whatever. 40 years later, it is still flys. Time to do some due dilligence Quote
DaV8or Posted July 18, 2012 Report Posted July 18, 2012 Quote: Mcstealth So if I am reading that correctly, in late 1971 with 1500 hours, the gear collapsed because of running off into the grass/mud/dirt, whatever. 40 years later, it is still flys. Time to do some due dilligence Quote
47U Posted July 19, 2012 Report Posted July 19, 2012 Dave has it absolutely correct. Any damage noted in the NTSB file needs to match to repairs documented in the log books AND with 337s filed in OKC. I know of a situation where the FAA had on file a 337 for a repair done long ago that was never entered into the airframe log and a 337 contained in the airframe log that was never sent in to the FAA. Go figure. Quote
Mcstealth Posted July 20, 2012 Author Report Posted July 20, 2012 This plane has a 30 hour new engine and Prop, inoperative auto pilot, 47 year old paint, average interior, and dated radios. No GPS. I will get a full rundown on Monday. Don't yet know why the brand new engine. David Quote
DaV8or Posted July 21, 2012 Report Posted July 21, 2012 Quote: Mcstealth Don't yet know why the brand new engine. David Quote
