Thedude Posted July 7, 2025 Report Posted July 7, 2025 My 79 J just started popping it's gear warning circuit breaker every time the gear is actuated. This happens on pulling the gear up as well as extending it. The breaker will not stay in while the gear is moving, but once it's done, it stays in and the lights all work fine. It's been fine for over 8 months until this last trip. Any ideas on where to look would be helpful.
EricJ Posted July 7, 2025 Report Posted July 7, 2025 Sounds like something is binding or there's an issue with the motor. I'd get it up on jacks and do some gear swings with the belly off and see what's up. Edit: Wait, never mind. If it's the gear warning popping that's going to be something different. First thing to check is to open up the ceiling panel where the Sonalerts are and make sure it's not contacting the metal roof. That's an easy place for a short and an easy fix if that's what it is. 2 1
GeeBee Posted July 7, 2025 Report Posted July 7, 2025 I've seen a bad gear over-ride switch pop the warning C/B
AH-1 Cobra Pilot Posted July 7, 2025 Report Posted July 7, 2025 If you do not have the retaining clip over the gear pump handle, your CB will pop once you move the gear handle to the UP position. Obviously, the gear will not go up, either.
Red Leader Posted July 7, 2025 Report Posted July 7, 2025 Make sure your gear override lever is completely locked.
PT20J Posted July 7, 2025 Report Posted July 7, 2025 The Gear Warning CB powers the gear down floor light, the Gear Down and Gear Unsafe annunciator lights and the gear warning sonalert (tone generator in later models). So, the symptoms indicate some issue in this circuitry. The only part of the circuit that is active when the gear is moving but not active when the gear is either up or down is the Gear Unsafe annunciator. I would look for a short circuit somewhere in this circuit. 4 1
Thedude Posted July 7, 2025 Author Report Posted July 7, 2025 Sounds like I should take a look at the ceiling. Pretty sure I hit my head on the ceiling a couple of times and that's hard enough to knock something loose. Thanks for the ideas, I'll report back once I get the time to look around in there.
Aerodon Posted July 7, 2025 Report Posted July 7, 2025 In the M20K, the gear warning CB also powers the gear unsafe horn through the throttle switch. And there are diodes in the wires near the sonalart. Diodes hurt my head. I would look at what is not working and start there: 1) gear unsafe annunciator 2) gear down light 3) gear unsafe horn - via up limit switch 4) gear unsafe via throttle limit switch. I would start with the gear unsafe light, it easiest to access. You are looking for a short to ground. Aerodon 1
skykrawler Posted July 7, 2025 Report Posted July 7, 2025 11 hours ago, AH-1 Cobra Pilot said: If you do not have the retaining clip over the gear pump handle, your CB will pop once you move the gear handle to the UP position. Obviously, the gear will not go up, either. Not the gear warning breaker. The manual extension lock will cause the actuator breaker to pop. 1
skykrawler Posted July 24, 2025 Report Posted July 24, 2025 Are we are left in the dark as to whether the problem was resolved?
Thedude Posted July 25, 2025 Author Report Posted July 25, 2025 Huh, I'm on this site like multiple times a day and I never got a notification of new replies. I thought I would be auto-following any topic I started... Either way, getting up into the headliner seems like a very time consuming task, and I'm pretty short on time atm, so I never started going down that path. I was curious about how the "gear unsafe" circuit worked, because when that would turn on is exactly when the CB pops and stays unresetable. So out of curiosity when I had an hour after work, I started pulling out the part of the panel that had the annunciator lights as that gear unsafe light is part of the circuit and this should be an easy task. It took like 10 minutes to pull out and realize what a can of worms that was going to be: the test button from the annunciator panel just fell off because the solder was non-existent and the face plate took some gymnastics to keep in place to put back together. 30 minutes or so I got it put back together (minus the test button) and all the lights still worked so I postponed for when I'd have more time. Fast forward to yesterday, I go for a flight and everything worked fine: gear unsafe light illuminated and no CB popped. I have no idea what the original issue was, but it's something related to where I was screwing around in the panel, which was mainly just the annunciator panel, however the CB panel is just one over from that and maybe I pulled on some wires and that removed the issue. I figured out how to remove the glare shield towards the end of my exploration the other day, so I'm going to spend some more time digging into this properly when I have the chance.
Fly Boomer Posted July 25, 2025 Report Posted July 25, 2025 8 minutes ago, Thedude said: I never got a notification of new replies. I thought I would be auto-following any topic I started... Go to your Profile > Account Settings > Notification Settings > Followed Content and specify what you want to receive. 1
Pinecone Posted July 25, 2025 Report Posted July 25, 2025 And you can see the notifications by clicking on the world icon at the upper right of any page. I get a pop up when I enter the forum that says I have X notifications.
Hank Posted July 25, 2025 Report Posted July 25, 2025 5 minutes ago, Pinecone said: I get a pop up when I enter the forum that says I have X notifications. Me, too, I just don't remember how I set it up. I do know that I dont want an email every time someone likes, quotes or responds to one of my posts.
Thedude Posted July 25, 2025 Author Report Posted July 25, 2025 19 minutes ago, Pinecone said: And you can see the notifications by clicking on the world icon at the upper right of any page. I get a pop up when I enter the forum that says I have X notifications. I'm on my phone and it shows the notifications at the bottom of the page, I just wasn't following this topic for some reason. I need to go through my settings as suggested above.
Hank Posted July 25, 2025 Report Posted July 25, 2025 2 minutes ago, Thedude said: I'm on my phone and it shows the notifications at the bottom of the page, I just wasn't following this topic for some reason. I need to go through my settings as suggested above. The appear down there just once, and also in the banner at the top until you open the list. 1
Thedude Posted March 7 Author Report Posted March 7 Top gun says the issue is a bad connection on the back of the gear bypass button. They're going to try to RTV it or get a salvage button if that doesn't work
Slick Nick Posted March 7 Report Posted March 7 2 hours ago, Thedude said: Top gun says the issue is a bad connection on the back of the gear bypass button. They're going to try to RTV it or get a salvage button if that doesn't work Sorry, what? RTV a wire Connection? 1
Hank Posted March 7 Report Posted March 7 14 minutes ago, Slick Nick said: Sorry, what? RTV a wire Connection? Yeah, I thought I had misread that . . . .
Thedude Posted March 7 Author Report Posted March 7 I'm sure I'm miscommunicating here, idk what RTV means, this is what Rachel described "would you prefer to try to RTV the pins in place first"
Slick Nick Posted March 7 Report Posted March 7 2 hours ago, Thedude said: I'm sure I'm miscommunicating here, idk what RTV means, this is what Rachel described "would you prefer to try to RTV the pins in place first" No, that makes sense. However that is a TERRIBLE idea. Is this not the same shop that told you your discharging electrical system was “fine”? I would get your plane away from that shop as fast as you possibly can.
Fly Boomer Posted March 7 Report Posted March 7 3 hours ago, Thedude said: I'm sure I'm miscommunicating here, idk what RTV means, this is what Rachel described "would you prefer to try to RTV the pins in place first" Room Temperature Vulcanization -- comes out like toothpaste; sets up like rubber.
Thedude Posted March 7 Author Report Posted March 7 1 hour ago, Slick Nick said: No, that makes sense. However that is a TERRIBLE idea. Is this not the same shop that told you your discharging electrical system was “fine”? I would get your plane away from that shop as fast as you possibly can. Really? Ya it's the same shop, Top Gun aviation in Stockton CA. They're supposed to be a good MSC from my understanding, they're referenced on this forum and from savvy as being a good shop...
Thedude Posted March 7 Author Report Posted March 7 What's the issue with doing RTV on this? Will it not last or will it cause other issues?
201Mooniac Posted March 8 Report Posted March 8 I’ve been using Top Gun for many years and they are a great shop but RTV in this context don’t really make sense to me. You would not RTV the wires to the switch so it sounds like the switch is coming apart which might be a reason to re-pot with RTV but I would think that is a really low probability of success solution and I’m surprised Rachel would suggest that to you.
