1980Mooney Posted May 30, 2025 Report Posted May 30, 2025 (edited) Great oil filter analysis conducted by KITPLANES Magizine. It shows that the reusable screen oil filters by Challenger and K&P are shockingly ineffective and cumulatively blind much more easily than traditional disposable pleated filters. Challenger claims 22 microns and K&P claims 35 microns effective removal however neither removed even 1% of particles in the 20-40 micron range. Examination by mesh calibration labs of the stainless-steel wire cloth in both screen filters showed that it is recognized as having only a 60 micron effective removal range within the process industry. The results show that they stop only the largest particles and that they blind off more easily In terms of effectiveness, they remind me of the old oil screens in the vintage VW air cooled Beetle engines. Oil Filter Testing - KITPLANES Edited May 30, 2025 by 1980Mooney 1
1980Mooney Posted May 31, 2025 Author Report Posted May 31, 2025 34 minutes ago, lithium366 said: These claims aside, I have a dumb question: with older airplanes having only oil screen, does fine particles oil filtering even have a noticeable impact on wear till (and past) TBO and will impact parts limits at overhaul? Carbon particulates from combustion byproducts in oil can be very abrasive especially as they clump together. 2
lithium366 Posted May 31, 2025 Report Posted May 31, 2025 (edited) 24 minutes ago, 1980Mooney said: Carbon particulates from combustion byproducts in oil can be very abrasive especially as they clump together. I have very little knowledge of what testing is done by FAA for STC but I am surprised and disappointed that K&P filters were never tested for their claims independently since they were used in cars for a while now, and also by FAA update: looks like some testing was done https://www.motor1.com/news/736893/metal-oil-filter-comparison-test/#:~:text=The results are decisive,Yikes https://bobistheoilguy.com/forums/threads/particle-count-comparisons-fram-ultra-vs-k-p-reusable-stainless-mesh-oil-filter.376224/#:~:text=Looks like below 20u the,must be ultra fine screen Edited May 31, 2025 by lithium366 1
Paul Thomas Posted June 1, 2025 Report Posted June 1, 2025 If you want to geek out, Van's Air Force forums, had a thread about it when the results came out.
0TreeLemur Posted June 1, 2025 Report Posted June 1, 2025 Very interesting. It seems that Wix is head-and-shoulders above the rest at total capture. Larger particles are more likely to do damage. I'd like to know what is the particle size where removal is a) most beneficial and b) essential for engine longevity?
