jamesyql Posted Monday at 01:16 AM Report Posted Monday at 01:16 AM I purchased an M20J this summer and have put 40 hours on it thus far. It has always banked left in cruise and the purpose of this thread is to journal the process to address and rectify the issue (ongoing) The issue: hands off cruise the plane starts banking left within 1-2 seconds and within 10 seconds the plane will be in a 15° left bank. Furthermore: stall practice has me hesitant as it consistently seems to want to drop the right wing. My reasoning tells me this is from the relatively higher AOA of the right wing needed to fly my plane straight into a stall, but I could be out to lunch on that. Diagnostic work thus far: I flew today for the purpose of evaluating the issue further following the flight test guidance found here: https://knr-inc.com/shoptalk-articles.html?view=article&id=75&catid=25 Conditions: just me in the plane (but it behaves this way with a passenger as well), full tanks (burning the left side first), 8500ft, WOT, 2500 RPM 8.5 GPH 117 KIAS Wings level test (using just aileron): turn coordinator ball slightly to the right of centre, just peeking past the white line. Wings level and ball centred test (used right aileron and right rudder to level wings and centre ball, then released aileron and kept rudder pressure): still banks left but not as dramatically as without rudder correction. In wings level cruise I will say that I *think* I could appreciate a slight positive angle upwards relative to the flap on the left aileron but tough to say for sure. So- my conclusion is that my plane is out of rig and both the left bank and yaw both need addressing. My mechanic is excellent, and I am confident he will be able to rig the plane, only thing is that he does not have the Mooney travel boards. I have read literally every thread on here about travel boards and rigging, so I feel that we should really try to get these to be confident in the static rigging before we start bending servo tabs. We are working to source them. I live in Alberta Canada which makes things more complicated if needing to source from the USA. I will keep this thread updated with my progress and experience with rigging my J partially as a place to journal my thoughts and also to help future riggers! James 1 Quote
Ragsf15e Posted Monday at 01:49 AM Report Posted Monday at 01:49 AM (edited) 35 minutes ago, jamesyql said: I purchased an M20J this summer and have put 40 hours on it thus far. It has always banked left in cruise and the purpose of this thread is to journal the process to address and rectify the issue (ongoing) The issue: hands off cruise the plane starts banking left within 1-2 seconds and within 10 seconds the plane will be in a 15° left bank. Furthermore: stall practice has me hesitant as it consistently seems to want to drop the right wing. My reasoning tells me this is from the relatively higher AOA of the right wing needed to fly my plane straight into a stall, but I could be out to lunch on that. Diagnostic work thus far: I flew today for the purpose of evaluating the issue further following the flight test guidance found here: https://knr-inc.com/shoptalk-articles.html?view=article&id=75&catid=25 Conditions: just me in the plane (but it behaves this way with a passenger as well), full tanks (burning the left side first), 8500ft, WOT, 2500 RPM 8.5 GPH 117 KIAS Wings level test (using just aileron): turn coordinator ball slightly to the right of centre, just peeking past the white line. Wings level and ball centred test (used right aileron and right rudder to level wings and centre ball, then released aileron and kept rudder pressure): still banks left but not as dramatically as without rudder correction. In wings level cruise I will say that I *think* I could appreciate a slight positive angle upwards relative to the flap on the left aileron but tough to say for sure. So- my conclusion is that my plane is out of rig and both the left bank and yaw both need addressing. My mechanic is excellent, and I am confident he will be able to rig the plane, only thing is that he does not have the Mooney travel boards. I have read literally every thread on here about travel boards and rigging, so I feel that we should really try to get these to be confident in the static rigging before we start bending servo tabs. We are working to source them. I live in Alberta Canada which makes things more complicated if needing to source from the USA. I will keep this thread updated with my progress and experience with rigging my J partially as a place to journal my thoughts and also to help future riggers! James There’s a good rigging article out there too… ill see if my google skills are up to the test… found it! https://knr-inc.com/shoptalk-articles.html?view=article&id=106&catid=25 Edited Monday at 01:51 AM by Ragsf15e 1 Quote
jamesyql Posted Monday at 01:52 AM Author Report Posted Monday at 01:52 AM There’s a good rigging article out there too… ill see if my google skills are up to the test… Nice googling!So far I have come across:https://knr-inc.com/shoptalk-articles.html?view=article&id=75&catid=25https://knr-inc.com/shoptalk-articles.html?view=article&id=106&catid=25https://themooneyflyer.com/issues/2017-OctTMF.pdfhttps://www.themooneyflyer.com/issues/2012-JulTMF.pdf Quote
Ragsf15e Posted Monday at 02:31 AM Report Posted Monday at 02:31 AM 37 minutes ago, jamesyql said: Nice googling! So far I have come across: https://knr-inc.com/shoptalk-articles.html?view=article&id=75&catid=25 https://knr-inc.com/shoptalk-articles.html?view=article&id=106&catid=25 https://themooneyflyer.com/issues/2017-OctTMF.pdf https://www.themooneyflyer.com/issues/2012-JulTMF.pdf Ahh, well you’re in good shape then! If you’re waiting on the boards, possibly worth a close look at the flaps to make sure they are both coming up fully and equally. Quote
jamesyql Posted Monday at 02:37 AM Author Report Posted Monday at 02:37 AM Ahh, well you’re in good shape then! If you’re waiting on the boards, possibly worth a close look at the flaps to make sure they are both coming up fully and equally.Edited post for brevity:We did drop the left flap as an initial attempt to fix the heavy wing, but no effect. Seems that this may be more effective for asymmetric wing drop with flap actuation. 1 Quote
PT20J Posted Monday at 03:42 AM Report Posted Monday at 03:42 AM First of all, these things were rigged correctly when they left the factory. The stall strips were put on with duct tape and after a couple of flight tests to get the position correct for stall with wings relatively level they were riveted in place. Unless the airplane has been damaged, the rigging shouldn't change. But what happens is that people mess with them over time and get the rigging messed up. You can check a few things yourself per the KNR article. If it's not right the best thing to do is to take it to a Mooney Service Center that has done rigging and has the travel boards and have them set it up correctly. 1 Quote
jamesyql Posted Monday at 03:45 AM Author Report Posted Monday at 03:45 AM First of all, these things were rigged correctly when they left the factory. The stall strips were put on with duct tape and after a couple of flight tests to get the position correct for stall with wings relatively level they were riveted in place. Unless the airplane has been damaged, the rigging shouldn't change. But what happens is that people mess with them over time and get the rigging messed up. You can check a few things yourself per the KNR article. If it's not right the best thing to do is to take it to a Mooney Service Center that has done rigging and has the travel boards and have them set it up correctly. I am hoping to source travel boards and have it done locally if possible. I don’t have much spare time to be travelling for maintenance and I trust my mechanic and have an excellent relationship with him. Even if it takes a bit longer than an MSC, it is worth it to me to keep everything in house. I should add that the right aileron [edit] trailing edge has also been bent downwards and correlates to a log book entry for a heavy left wing from years ago.My goal is to get the static rigging checked and adjusted since the plane is new to me and then I will have a better starting point if needing to modify tabs any further.Will also have engine mounts checked. Quote
PT20J Posted Monday at 03:35 PM Report Posted Monday at 03:35 PM 11 hours ago, jamesyql said: I should add that the right aileron servo tab has also been modified and correlates to a log book entry for a heavy left wing from years ago. Stock M20Js don’t have aileron servo tabs. Does your airplane have an Aero-Trim installed? Quote
jamesyql Posted Monday at 03:40 PM Author Report Posted Monday at 03:40 PM Stock M20Js don’t have aileron servo tabs. Does your airplane have an Aero-Trim installed?apologies, wrong lingo. Thanks for the clarification. I was referring to the aileron trailing edge which can be bent. Still learning all of this, new to plane ownership and Mooneys. Edited above post to avoid confusion to others. 2 Quote
EricJ Posted Monday at 05:26 PM Report Posted Monday at 05:26 PM 13 hours ago, PT20J said: Unless the airplane has been damaged, the rigging shouldn't change. But what happens is that people mess with them over time and get the rigging messed up. Regular maintenance happens, too, and rod ends and flap hinges and control surfaces and such get replaced over time. Every time an airplane is painted it gets re-rigged. ADs and SBs get performed that are intrusive to flight controls, etc. There are lots of opportunities for rigging to get disturbed over the decades that our airplanes have been around. I'm a little surprised most of them are as good as they are. Quote
Sue Bon Posted Monday at 05:37 PM Report Posted Monday at 05:37 PM I had this problem for a while, but with banking to the left. My maintainer fixed it by trimming the rudder. 1 Quote
Pinecone Posted Monday at 06:54 PM Report Posted Monday at 06:54 PM Who are the best shops for rigging? Quote
jamesyql Posted Monday at 07:37 PM Author Report Posted Monday at 07:37 PM Secured travel board rental from nearby MSC. Correction: they only have the elevator board. The hunt continues. Mechanic going to chat with Lasar. Aaaaand, we found them locally(ish) after all. Will update back once we have had a chance to get the plane in the shop. 1 Quote
Fly Boomer Posted Tuesday at 02:06 AM Report Posted Tuesday at 02:06 AM 10 hours ago, jamesyql said: I was referring to the aileron trailing edge which can be bent. I wouldn't allow anyone near my flight controls with pliers unless more than one Mooney rigging expert told me it was the only way. 1 Quote
jamesyql Posted Tuesday at 02:18 AM Author Report Posted Tuesday at 02:18 AM I wouldn't allow anyone near my flight controls with pliers unless more than one Mooney rigging expert told me it was the only way.Fair enough. I am hoping that by addressing the static rigging many of the issues will resolve. 1 Quote
Ragsf15e Posted Tuesday at 03:06 AM Report Posted Tuesday at 03:06 AM 42 minutes ago, jamesyql said: Fair enough. I am hoping that by addressing the static rigging many of the issues will resolve. Getting the rigging right first is important but at the end, a very small tweak on the aileron trailing edge is very effective. On my first (very expensive) annual, a very popular (and expensive, and knowledgeable) MSC said the rigging was all messed up. They were also replacing a trim tube and some heim joints. Anyway, they used the boards and got her all squared away, then told me to go fly it and see what happens. Well, it had a pretty solid right roll (I have a video somewhere that I took to show them). The “big boss” of the shop looked at the video, took a pair of duckbill pliers and slightly tweaked the left aileron. You can’t see the bend, it’s very small. Totally straightened it out. So if you get there after the boards, it’s not the end of the world. 4 Quote
