After annual, cant get the idle down
So another thing i am trying to tackle is the idle,  was idling around 700 before, changed a lot of things, my mechanic has a sonicator and cleaned out a lot of negligence.  Lot of fuel lines were replaced with the new JPI that was installed, a new baffling system, but nothing in the engine itself.  It now wants to idle at 1100.  Mechanic is scratching his head because he did touch anything engine wise.
Is there an idle screw and what is everyones idle rpm?   I scream at taxiing now!
Link to comment
Share on other sites
Yes there is an idle screw and it’s very easy to find.
Sounds like you’re really not familiar so get someone to move the throttle, you will see an arm moving, when the throttle is fully closed the arm should rest against a screw, it will be pretty obvious.
I’m guessing it won’t be, if it’s not adjusting the screw will do no good, as I’m guessing, my guess is that the throttle cable has slipped.
This really is very easy stuff, same as a lawnmower, if it has your mechanic stumped it makes me wonder
Link to comment
right side correct(pax side)
Link to comment
You need to get to the bottom of what changed first.  If no adjustments were made something has slipped or shifted.  There is and idle screw on the right side of the fuel injection servo.  Typically idle is set to 600-625, even lower if you’re on a short strip.
Link to comment
If it was an annual inspection did he not clean the plugs, maybe readjust timing, maybe clean the injectors?    An increased idle may also be an indication of a vacuum leak, so if something was moved/bumped/adjusted that affected vacuum, e.g., the manifold pressure line, that can also affect idle.
Link to comment
