Shadrach Posted January 25, 2023 Report Share Posted January 25, 2023 If anyone has some detailed insight into modes of thermocouple failure, I would greatly appreciate a synopsis. After adding a CHT probe piggy back and rebundling the wiring at annual, my #3 EGT is intermittent. It was part of the rerouted at annual. It was not dropped nor externally damaged during R&R. It always ops checks fine in the hangar but drops out at start up. It then randomly cycles between delivering no data, inaccurate data and accurate data. I have triple checked the connections. Obviously I induced the failure by removing and reinstalling. I am trying to understand how/why. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
EricJ Posted January 25, 2023 Report Share Posted January 25, 2023 1 hour ago, Shadrach said: If anyone has some detailed insight into modes of thermocouple failure, I would greatly appreciate a synopsis. After adding a CHT probe piggy back and rebundling the wiring at annual, my #3 EGT is intermittent. It was part of the rerouted at annual. It was not dropped nor externally damaged during R&R. It always ops checks fine in the hangar but drops out at start up. It then randomly cycles between delivering no data, inaccurate data and accurate data. I have triple checked the connections. Obviously I induced the failure by removing and reinstalling. I am trying to understand how/why. Thanks in advance. They are sensitive to continuity, so if all of the connections aren't clean and stable you can get what you're seeing, but you probably know that. The break could be within a wire, though, or potentially within the probe. Have you tried swapping probes around to try to isolate it? Quote Link to comment Share on other sites More sharing options...
kortopates Posted January 25, 2023 Report Share Posted January 25, 2023 In addition to what Eric says above, also check for any chaffing in the wire harness between the probe junction and the firewall. Any found chaffing needs to be repaired with shrink sleeving since it can lead to grounding of the thermocouple wire. Quote Link to comment Share on other sites More sharing options...
Shadrach Posted January 25, 2023 Author Report Share Posted January 25, 2023 Thanks gents, The harness is well isolated. It is protected with spiral wrap and is protected with fire sleeve in areas near the engine. Connectors were cleaned prior to joining and we’re shrink wrapped. The probe itself does show some external deterioration. Swapping was my first thought, but I Who is weary of the potential for creating additional problems. The leads are different lengths so that the connections are staggered throughout the harness to avoid creating a large bulge. Does anyone know offhand what the resistance reading should be? Quote Link to comment Share on other sites More sharing options...
EricJ Posted January 25, 2023 Report Share Posted January 25, 2023 2 hours ago, Shadrach said: Thanks gents, The harness is well isolated. It is protected with spiral wrap and is protected with fire sleeve in areas near the engine. Connectors were cleaned prior to joining and we’re shrink wrapped. The probe itself does show some external deterioration. Swapping was my first thought, but I Who is weary of the potential for creating additional problems. The leads are different lengths so that the connections are staggered throughout the harness to avoid creating a large bulge. Does anyone know offhand what the resistance reading should be? Thermocouples generate voltage proportional to temperature, but the voltages tend to be very low, in the millivolt range even when very hot. This means resistance isn't really a spec for the thermocouple itself. The main way to test them is get them hot and see if they follow the expected voltage/temp response. 1 Quote Link to comment Share on other sites More sharing options...
MikeOH Posted January 26, 2023 Report Share Posted January 26, 2023 I believe the TC junction itself is formed by a small weld. It may be this weld has failed and the connection is intermittent and temperature sensitive. If so, you need a new EGT probe. Quote Link to comment Share on other sites More sharing options...
carusoam Posted January 26, 2023 Report Share Posted January 26, 2023 9 hours ago, EricJ said: Thermocouples generate voltage proportional to temperature, but the voltages tend to be very low, in the millivolt range even when very hot. This means resistance isn't really a spec for the thermocouple itself. The main way to test them is get them hot and see if they follow the expected voltage/temp response. Even smaller… microvolts. So… a broken wire, weld, or corroded connection, or dirty connection, can be problematic… Vibration challenges are a sign of a break… Chasing a problem, connection by connection… probably going to be a ton o work… Plan B… abandon the old wire in place… install a new one from end to end… If it is bad data… Its chasing each part of the wire again… each connection and wire… to make sure it is the proper wire making the proper connection… Make sure even the right screws are used… Keep in mind there are some situations where a connector isn’t made out of the same materials the tc is made from… this is OK because it is balanced when the installation is uniformly using the same connectors… use caution if a connector was replaced or its hardware was different… We can always invite @oregon87 to see if he has any insight on this TC challenge…? PP thoughts only, not a mechanic… Best regards, -a- Quote Link to comment Share on other sites More sharing options...
oregon87 Posted January 26, 2023 Report Share Posted January 26, 2023 (edited) Connections, connections, connections. The vast majority of erratic/erroneous indications are connection related. I can spin yards about troubleshooting connections. Even if the connections look good, replace them. That's typically the first step in troubleshooting. If the problem persists, swap the probe with another cylinder. If the problem follows the probe, you've found your problem. If the problem stays with the cylinder, that cylinder's wiring between the probe and instrument should be further investigated. Edited January 26, 2023 by oregon87 1 Quote Link to comment Share on other sites More sharing options...
