What year did Mooney start using electric speedbrakes on Bravo's
bknight
11 hours ago, bknight said:
What year did Mooney switch from vacuum driven to using electric speedbrakes on Bravo's. Still educating myself.
Thanks,
In 1989 when the M20M (TLS) was introduced it had vacuum speed brakes. I owned serial number 27-0007 which had vacuum brakes, which were called Descent Control Devices. The 1993 TLS, serial number 27-0150 that I owned had electric speed brakes, so somewhere in between 1989 and 1993 they switched from vacuum to electric. If I remember correctly though it was just the 1989 models that had vacuum speed brakes. Someone with a 1990 model will chime in I'm sure.
Link to comment
Share on other sites
I don't have the answer but I DO have the Precise Flight 100 series (original electric speed brakes).  Here is the STC that at least shows when they were approved.  Looks like late 1988, but I'm not sure what the 1991 revision was regarding.
Link to comment
