Greg Ellis Posted November 8, 2022 Report Share Posted November 8, 2022 With all that old sealant removed and the new sealant done correctly with the proper thickness....you just might gain a couple of gallons of useful fuel!!! 1 Quote Link to comment Share on other sites More sharing options...
Kelpro999 Posted November 8, 2022 Report Share Posted November 8, 2022 8 hours ago, ArtVandelay said: Great, except you’ll need to repaint the wings. Yeah, it’s definitely not for saving paint Quote Link to comment Share on other sites More sharing options...
rrodriguzzi1 Posted November 9, 2022 Author Report Share Posted November 9, 2022 Polygone works. You have to have the right temp and a lot of patience. Works best with the original sealant. It doesn’t do well on the patches. I had to pull or scrape them off. Lots of patience. I did used aluminum tape around the access cut outs. That will protect against Polygone or any other stripper. I am painting that section on both wings later on. Quote Link to comment Share on other sites More sharing options...
carusoam Posted November 9, 2022 Report Share Posted November 9, 2022 +1 for finding and knowing…. Ribs at the top have vent holes… Ribs at the bottom have drain holes…. Usable fuel depends on all of these holes be available to transfer air and fuel to the other side of the ribs… Best regards, -a- 1 Quote Link to comment Share on other sites More sharing options...
rrodriguzzi1 Posted November 9, 2022 Author Report Share Posted November 9, 2022 Can you buy D-Zolve in smaller amounts or quantities? Like, a gallon should do one side. Quote Link to comment Share on other sites More sharing options...
rrodriguzzi1 Posted November 9, 2022 Author Report Share Posted November 9, 2022 That’s the website for D-Zolve. Quote Link to comment Share on other sites More sharing options...
Kelpro999 Posted November 9, 2022 Report Share Posted November 9, 2022 20 minutes ago, rrodriguzzi1 said: Can you buy D-Zolve in smaller amounts or quantities? Like, a gallon should do one side. They will give you a free pint for the asking but the smallest quantity for sale is 5 gallon pale. Quote Link to comment Share on other sites More sharing options...
rrodriguzzi1 Posted November 9, 2022 Author Report Share Posted November 9, 2022 Great! Whatever saves me time will be great! Got other projects going on. I will post the results / comparison with or against Poly-Gone. Which have work for me in the past. It just takes time. Thanks 2 Quote Link to comment Share on other sites More sharing options...
rrodriguzzi1 Posted November 9, 2022 Author Report Share Posted November 9, 2022 Actually, they responded right away to my email. 90 bucks per gallon. 1 Quote Link to comment Share on other sites More sharing options...
Igor_U Posted November 18, 2022 Report Share Posted November 18, 2022 On 11/8/2022 at 6:57 PM, rrodriguzzi1 said: Polygone works. You have to have the right temp and a lot of patience. Works best with the original sealant. It doesn’t do well on the patches. I had to pull or scrape them off. Lots of patience. I did used aluminum tape around the access cut outs. That will protect against Polygone or any other stripper. I am painting that section on both wings later on. Great job of documenting your tank work, thank you. How much Sealant did you use for your job and which one? Did you use cartridge applicator or stuff in a can? Quote Link to comment Share on other sites More sharing options...
Igor_U Posted November 18, 2022 Report Share Posted November 18, 2022 Mooney service manual recommends PR1403-G-B2 for sealing removable access panels in the tank. I read it is discontinued in North America. What do you typically use as a replacement? Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted November 18, 2022 Report Share Posted November 18, 2022 16 minutes ago, Igor_U said: Mooney service manual recommends PR1403-G-B2 for sealing removable access panels in the tank. I read it is discontinued in North America. What do you typically use as a replacement? The manual lists three different sealants for access panels. CS-3330-B PR1403-G-B2 PR1428-B You will find one of them. 1 Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted November 18, 2022 Report Share Posted November 18, 2022 19 minutes ago, Igor_U said: Mooney service manual recommends PR1403-G-B2 for sealing removable access panels in the tank. I read it is discontinued in North America. What do you typically use as a replacement? I just Googled PR1403-G-B2 and got about 5 pages of places selling it. Quote Link to comment Share on other sites More sharing options...
Igor_U Posted November 18, 2022 Report Share Posted November 18, 2022 1 minute ago, N201MKTurbo said: The manual lists three different sealants for access panels. CS-3330-B PR1403-G-B2 PR1428-B You will find one of them. Well, not my 1967 SM. I do have somewhere newer manuals that this info is coming from but not on work computer. Thank you Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted November 18, 2022 Report Share Posted November 18, 2022 I have found the best place to get sealant is through Boeing. Find a repair shop with a parts department and have them order it for you. It is usually faster and cheaper than ordering on line. 1 Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted November 18, 2022 Report Share Posted November 18, 2022 2 minutes ago, Igor_U said: Well, not my 1967 SM. I do have somewhere newer manuals that this info is coming from but not on work computer. Thank you That was from a J manual. Same wing, same tank, I doubt anyone would give you any grief for it. 1 Quote Link to comment Share on other sites More sharing options...
Igor_U Posted November 18, 2022 Report Share Posted November 18, 2022 Just now, N201MKTurbo said: That was from a J manual. Same wing, same tank, I doubt anyone would give you any grief for it. I understand, that was my next search when I get a hold of my personal computer. 2 minutes ago, N201MKTurbo said: I have found the best place to get sealant is through Boeing. Find a repair shop with a parts department and have them order it for you. It is usually faster and cheaper than ordering on line. By Boeing you mean Avial? I HATE when they call "heritage company McDonnel" and such and rebrand or claim they invented everything. They would call a DC-3 Boeing! Your Google people must be better than my google people. I got 5 pages, all right but no sale prices, only a few RFQ. Cheers Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted November 18, 2022 Report Share Posted November 18, 2022 1 minute ago, Igor_U said: I understand, that was my next search when I get a hold of my personal computer. By Boeing you mean Avial? I HATE when they call "heritage company McDonnel" and such and rebrand or claim they invented everything. They would call a DC-3 Boeing! Your Google people must be better than my google people. I got 5 pages, all right but no sale prices, only a few RFQ. Cheers Yes, I liked Aviall better, but its Boeing now weather we like it or not. Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted November 18, 2022 Report Share Posted November 18, 2022 You can get it from Sky Geek, but they don't stock it, they order it from Boeing and then ship it to you after they get it, so it takes two shipping delays to get it. 1 Quote Link to comment Share on other sites More sharing options...
Fly Boomer Posted November 19, 2022 Report Share Posted November 19, 2022 1 hour ago, Igor_U said: Mooney service manual recommends PR1403-G-B2 for sealing removable access panels in the tank. I read it is discontinued in North America. What do you typically use as a replacement? ChemSeal CS-3204 https://www.aircraftspruce.com/catalog/pnpages/09-38500.php ChemSeal CS-3330 https://pilotshq.com/products/chemseal-cs3330-low-adhesion-access-door-sealant-6-oz-cs3330b2kit The first one goes inside the tank, and the second (low adhesion) is used on the access covers. 3 Quote Link to comment Share on other sites More sharing options...
Shadrach Posted November 19, 2022 Report Share Posted November 19, 2022 1 hour ago, Igor_U said: Well, not my 1967 SM. I do have somewhere newer manuals that this info is coming from but not on work computer. Thank you PR1403 was discontinued in North America a long time ago. Use CS3330 or equivalent. 1 Quote Link to comment Share on other sites More sharing options...
rrodriguzzi1 Posted November 22, 2022 Author Report Share Posted November 22, 2022 (edited) I haven’t got to the materials part yet. Busy with other airplanes. I will post the information as soon as I get to it. Now, here are some pictures of what using the wrong hardware ( too long ) to your access panels. can do, creating more leaks in the process. That’s also PolyGone at work on the access panels with original sealant. Edited November 23, 2022 by rrodriguzzi1 Word correction 2 Quote Link to comment Share on other sites More sharing options...
Shadrach Posted November 23, 2022 Report Share Posted November 23, 2022 @rrodriguzzi1 are you using polygon gel or polygon liquid? I found the liquid to be far more effective but challenging to lay down precisely for small repairs. Quote Link to comment Share on other sites More sharing options...
Shadrach Posted November 23, 2022 Report Share Posted November 23, 2022 You’re braver than I. I’d be very afraid of anyone using a powered brush in my tank might round off rivet heads and render them unairworthy. 1 Quote Link to comment Share on other sites More sharing options...
rrodriguzzi1 Posted November 23, 2022 Author Report Share Posted November 23, 2022 Yes. You just have to know when to stop. Talking about rivets, there’s about 8 to 10 rivets in this tank that were unairworthy right out of the factory. I will add pictures of that later. Quote Link to comment Share on other sites More sharing options...
