Propeller Control Cable Swivel Joint Replacement?
tkubat06
Airplane: ‘66 E
Does anyone know if there is a replacement available for this swivel joint at the end of my propeller cable? It popped loose today during my run up. I had an A&P take a quick look and said it looked worn out. I plan to get it pulled off to be sure but am curious is there is a more modern replacement available. There is a ball on the other side of that castle nut that inserts into that hole in the link above.
Thanks!
p.s. The cotter pin is bent like that because I was in the process of removing it when it took the pic.
Edited by tkubat06
Link to comment
Share on other sites
They can be replaced with a standard Heim style rod end bearing, a bolt, nut and cotter pin.  There is a kit from Mooney for this.
By the way, that looks more like your propeller governor, not your throttle
Link to comment
Awesome thank you. Yeah, meant propeller control cable.
Link to comment
Ok, so I contacted LASAR and highly recommend Mooney Mechanic. LASAR sells a kit to replace this old ball joint connection with a Heim fitting (kit 660051-005), and it's $215. The equivalent list of components from Aircraft Spruce are $20 and they are
- Heim Bushing: MW-3M
- Drilled Bolt: AN3C-11
- Spacer (not needed if you use washers): 550017-005
- Washer: AW960-10
- Nut: AW310-3
- Cotter Pin: AW380-2-2
You should OF COURSE buy the $215 kit. :-)
Attached is a picture of the Heim fitting for reference.
Edited by tkubat06
Link to comment
  • 8 months later...
