Philip France 13 Posted September 10, 2022 Report Share Posted September 10, 2022 Hello Engine pressure reading too high on fresh installed G3X EIS. I estimate is reading 3 to 4 inch too high, anybody had similar issue, Quote Link to comment Share on other sites More sharing options...
EricJ Posted September 10, 2022 Report Share Posted September 10, 2022 Which pressure are you worried about? They all seem okay. Edit: I'm guessing you mean manifold pressure. At 10kft that does seem high if you don't have a turbo. When on the ground you can compare it to your altimeter setting with appropriate conversions for field elevation to determine whether it is off or how much. 1 Quote Link to comment Share on other sites More sharing options...
PT20J Posted September 10, 2022 Report Share Posted September 10, 2022 There is no calibration on the G3X for manifold pressure, so it is most likely a bad transducer. It’s also good to check that the tiny drain hole in the line is clear to keep liquid from making it’s way to the transducer. 1 Quote Link to comment Share on other sites More sharing options...
Philip France 13 Posted September 12, 2022 Author Report Share Posted September 12, 2022 Thank you i will check it Quote Link to comment Share on other sites More sharing options...
