m20k TKS stall strip
hi all , this is my first post here. I'm wondering if anyone knows if the stall strip (TKS) for the mooney m20k 1979 vintage is the same as any other aircraft so I can broaden my search for a stall strip. any help or advice would be appreciated.
Link to comment
Share on other sites
1 hour ago, carusoam said:
M20K305 sounds like a Rocket…
See if @aviatoreb is familiar with TKS strips getting free….
Yup - they can fall off!  Had one fall off in flight and fall right into Lake Michigan from 17k!  If anyone finds it please let me know and I will send my address.
In that case, one was not obtainable/available for like 4 months!
Best to add check the stall strips to your preflight - just touch them and make sure they are secure - no need to yank them - and perhaps re-glue them in any case at least every decade?
Link to comment
I had one break free, but there is also a feed tube behind it that connects in the back. Mine was dangling by the metal tube. I re-attached with the secret sauce adhesive, and redid the other at the same time as it was also loose.
If your came right off, there might be other damage with the missing tube, so a bit more than just gluing a new one on.
Link to comment
tube is good ! thanks
Link to comment
I've added them to my preflight.  A little tape will get you home if you catch them before they fall off.  The fuel tank adhesive is easy to make a mess with.  Glove are your friend.
Link to comment
 Share
