timpercarpio Posted August 2, 2022 Author Report Share Posted August 2, 2022 I like the idea of just using sheepskin as inserts without wrapping around the whole seat. Any ideas how to do that? I’ll check with a local interior shop. Quote Link to comment Share on other sites More sharing options...
Marauder Posted August 2, 2022 Report Share Posted August 2, 2022 Chris, I should be there about 10:00-10:30. I’ll head out before 10. Let me know if your plans change. Sent from my iPhone using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
Marauder Posted August 2, 2022 Report Share Posted August 2, 2022 I like the idea of just using sheepskin as inserts without wrapping around the whole seat. Any ideas how to do that? I’ll check with a local interior shop. SureFlight at KMQS can do it. I think it might be a bit more expensive because it would be a custom fit. Sent from my iPhone using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted August 3, 2022 Report Share Posted August 3, 2022 3 hours ago, timpercarpio said: I like the idea of just using sheepskin as inserts without wrapping around the whole seat. Any ideas how to do that? I’ll check with a local interior shop. Here's an idea of what it would look like (scroll through the pictures and look for the front seats): https://www.aircraft.com/aircraft/1464109/n252bh-1987-mooney-m20k-encore Personally I think it looks a little like Mr. T from the '80's: https://www.imdb.com/name/nm0001558/ 1 Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted August 3, 2022 Report Share Posted August 3, 2022 With some taller/larger side bolsters (like a sports car seat) I think it wouldn't be much like Mr T. 252BH's seats look great either way, though. That is a fantastic Mooney.Sent from my LM-V450 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Will.iam Posted August 4, 2022 Report Share Posted August 4, 2022 On 8/2/2022 at 8:56 PM, KSMooniac said: With some taller/larger side bolsters (like a sports car seat) I think it wouldn't be much like Mr T. 252BH's seats look great either way, though. That is a fantastic Mooney. Sent from my LM-V450 using Tapatalk I noticed that airplane had a gear up landing due to failure of the noback spring. Is this the only known famous no back spring failure or is this a new different one making this a trend now instead of a rarity. Also if you were to find yourself stuck in this situation of having to land gear up, is it better to land on a grass field, or concrete? Full flaps or partial flaps or no flaps? I know on the T-37 “tweet” if the gear failed to come down we were instructed to land with full flaps and speedbrake deployed. Since the speedbrake was a big flap under the nose, you essentially landed on just the flaps and speedbrake and saved the rest of the body and wings from damage. It was a quick swap of the flap and speedbrake pieces and fix whatever caused the gear not to come down in the first place but usually they had the plane back in operations within a day or 2. I just wonder what configuration would be the least damaging / quickest to fix? Quote Link to comment Share on other sites More sharing options...
Hank Posted August 4, 2022 Report Share Posted August 4, 2022 @Will.iam, use the configuration that will put you down for a normal landing, at normal speed and location in the runway. And concrete is considered best, because there are no holes to nose into, and the antennae, etc., on your belly won't dig in and make you spin, roll or nose over. Be aware, though, that gear up you will be faster than you expect! That's a lot of drag you will not have. Quote Link to comment Share on other sites More sharing options...
Will.iam Posted August 4, 2022 Report Share Posted August 4, 2022 6 hours ago, Hank said: @Will.iam, use the configuration that will put you down for a normal landing, at normal speed and location in the runway. And concrete is considered best, because there are no holes to nose into, and the antennae, etc., on your belly won't dig in and make you spin, roll or nose over. Be aware, though, that gear up you will be faster than you expect! That's a lot of drag you will not have. Thanks. I hope to never have to need this info but good to have in case murphy strikes. Quote Link to comment Share on other sites More sharing options...
