Martin S. Posted July 6, 2022 Report Share Posted July 6, 2022 Evening everybody, My 1978 M20J has the wing tip stc with strobes. One of the strobe bulbs broke. I am therefore considering to go with LEDS. I thought the 650E series LED strobes were STCed for the M20J. However, the STC does not mention the J. Am I overlooking something here? Greets, Martin Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted July 6, 2022 Report Share Posted July 6, 2022 Maybe because those models didn’t have the wingtips that take the 650E, starting with J they did, so an STC is not required? Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted July 6, 2022 Report Share Posted July 6, 2022 Check with your IA, but standard TSO lights & strobes are minor mods and thus do not require an STC. That is the interpretation of every reasonable IA that I know. YMMV 2 Quote Link to comment Share on other sites More sharing options...
atpdave Posted July 7, 2022 Report Share Posted July 7, 2022 I’m not a maintenance expert, but I think STC SA800EA allows strobe installations on aircraft not originally equipped with strobes and would not apply to M20Js and later models. Martin’s wingtip STC assures that with the newer wingtips the lighting coverage still complies with regulatory requirements, among other things like aerodynamic and structural issues. Replacing the nav/strobe assembly with 650E LEDs in the newer wingtips should be a minor mod with no other STC required. 1 Quote Link to comment Share on other sites More sharing options...
OSUAV8TER Posted July 8, 2022 Report Share Posted July 8, 2022 One big reason why there may be no STC for your particular type aircraft is because Whelen used existing STCs to get the LED lights certified. If the aircraft came with Whelen lights as OEM equipment then there was no STC to piggy back off. Rest assured they are all FAA TSO approved as an anti-collision and night position light. The proper pathway to modifying the aircraft is through a minor alteration with a logbook entry. No 337 and no IA sign off. Quote Link to comment Share on other sites More sharing options...
OSUAV8TER Posted July 8, 2022 Report Share Posted July 8, 2022 Following now. Quote Link to comment Share on other sites More sharing options...
Martin S. Posted July 8, 2022 Author Report Share Posted July 8, 2022 Got a little follow up question. I have the Whelen legacy A625 strobe/nav lights. Which LED version of the Orion line would be the best replacement for these? It seems the Orion 650 and 650E are replacements for the legacy 650 series and there is no Orion 625E product. Are the Orion 650/Es compatible with the legacy 625? Greets, Martin Quote Link to comment Share on other sites More sharing options...
OSUAV8TER Posted July 8, 2022 Report Share Posted July 8, 2022 18 minutes ago, Martin S. said: Got a little follow up question. I have the Whelen legacy A625 strobe/nav lights. Which LED version of the Orion line would be the best replacement for these? It seems the Orion 650 and 650E are replacements for the legacy 650 series and there is no Orion 625E product. Are the Orion 650/Es compatible with the legacy 625? Greets, Martin Hi Martin, probably an Orion 650E. So the A625 is embedded behind a lens in your wingtip, correct? I have the Orion 650E in stock. Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted July 8, 2022 Report Share Posted July 8, 2022 5 hours ago, OSUAV8TER said: One big reason why there may be no STC for your particular type aircraft is because Whelen used existing STCs to get the LED lights certified. If the aircraft came with Whelen lights as OEM equipment then there was no STC to piggy back off. Rest assured they are all FAA TSO approved as an anti-collision and night position light. The proper pathway to modifying the aircraft is through a minor alteration with a logbook entry. No 337 and no IA sign off. What i think will need an IA sign off though is the change in weight and balance due to removing the Power Supplies. Correct me if I'm wrong. Quote Link to comment Share on other sites More sharing options...
OSUAV8TER Posted July 8, 2022 Report Share Posted July 8, 2022 15 minutes ago, LANCECASPER said: What i think will need an IA sign off though is the change in weight and balance due to removing the Power Supplies. Correct me if I'm wrong. Does an IA have to sign off on a revised W&B? I'm not sure about that. Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted July 8, 2022 Report Share Posted July 8, 2022 5 minutes ago, OSUAV8TER said: Does an IA have to sign off on a revised W&B? I'm not sure about that. You may be right. Quote Link to comment Share on other sites More sharing options...
Martin S. Posted July 9, 2022 Author Report Share Posted July 9, 2022 On 7/8/2022 at 6:59 PM, OSUAV8TER said: Hi Martin, probably an Orion 650E. So the A625 is embedded behind a lens in your wingtip, correct? I have the Orion 650E in stock. Yes, my 625 is behind a lens. I'll try to make some fotos next time, just to check the assembly for compatibility. Quote Link to comment Share on other sites More sharing options...
EricJ Posted July 9, 2022 Report Share Posted July 9, 2022 On 7/8/2022 at 11:14 AM, LANCECASPER said: What i think will need an IA sign off though is the change in weight and balance due to removing the Power Supplies. Correct me if I'm wrong. An A&P can do that. 2 Quote Link to comment Share on other sites More sharing options...
Niko182 Posted July 9, 2022 Report Share Posted July 9, 2022 On 7/8/2022 at 12:36 PM, LANCECASPER said: You may be right. a new weight and balance doesn't need to be done. However it is worth while in my opinions since you can never have too much useful load. It's a small difference, but multiple small differences add up to a big one. Quote Link to comment Share on other sites More sharing options...
atpdave Posted July 10, 2022 Report Share Posted July 10, 2022 The IA who inspected my LED upgrade thought the minor weight change was enough to do a W&B update. Easy to do; why not do it? Quote Link to comment Share on other sites More sharing options...
KB4 Posted July 10, 2022 Report Share Posted July 10, 2022 12 hours ago, atpdave said: minor weight change Power supplies about 2-3 lbs each plus mounting bolts nuts washers, it will add up. Shed about 10 lbs. U need new W&B. 2 Quote Link to comment Share on other sites More sharing options...
carusoam Posted July 10, 2022 Report Share Posted July 10, 2022 One thing to keep an eye on when going LEDs… Some annunciator panels sense the nav lights being on or off for the dimming function… Another minor wire change may be required to keep the dimming function alive… Best regards, -a- Quote Link to comment Share on other sites More sharing options...
EricJ Posted July 10, 2022 Report Share Posted July 10, 2022 A new W&B is required whenever a repair or alteration is made that changes the W&B. Often if the difference in the weight is less than a pound no change is made since it would arguably not result in a significant numerical change in the results. An alteration with a net removal of a few pounds would make a numerical change in the empty weight and so it would be tough to argue that it doesn't need to be updated. These accumulated small changes over many alterations over time are one reason why people are often reluctant to weigh their airplanes, because the many-times-updated and perhaps-many-more-times-not-updated W&B sheet may have a lot of accumulated errors compared to actual. 1 Quote Link to comment Share on other sites More sharing options...
Martin S. Posted July 10, 2022 Author Report Share Posted July 10, 2022 5 hours ago, carusoam said: One thing to keep an eye on when going LEDs… Some annunciator panels sense the nav lights being on or off for the dimming function… Another minor wire change may be required to keep the dimming function alive… Best regards, -a- Thanks! Quote Link to comment Share on other sites More sharing options...
Martin S. Posted July 10, 2022 Author Report Share Posted July 10, 2022 On 7/8/2022 at 6:59 PM, OSUAV8TER said: Hi Martin, probably an Orion 650E. So the A625 is embedded behind a lens in your wingtip, correct? I have the Orion 650E in stock. Here you go, took some fotos and measurements. Seems the mounting scheme of the screws of my legacy light is compatible with the one of the 650E (three screws in triangle with distance1 = 1,75 inch and distance2 = 1 inch). Can you confirm? Greets, Martin Quote Link to comment Share on other sites More sharing options...
Guest Posted July 10, 2022 Report Share Posted July 10, 2022 1 hour ago, Martin S. said: Here you go, took some fotos and measurements. Seems the mounting scheme of the screws of my legacy light is compatible with the one of the 650E (three screws in triangle with distance1 = 1,75 inch and distance2 = 1 inch). Can you confirm? Greets, Martin In my experience the mounting for Grimes navigation lights (which you have) and Whelen, are the same. Clarence Quote Link to comment Share on other sites More sharing options...
OSUAV8TER Posted July 10, 2022 Report Share Posted July 10, 2022 2 hours ago, Martin S. said: Here you go, took some fotos and measurements. Seems the mounting scheme of the screws of my legacy light is compatible with the one of the 650E (three screws in triangle with distance1 = 1,75 inch and distance2 = 1 inch). Can you confirm? Greets, Martin Yes the Orion 650E is a direct replacement for that. I have them in stock and I can ship them where every you like. Quote Link to comment Share on other sites More sharing options...
KB4 Posted July 11, 2022 Report Share Posted July 11, 2022 21 hours ago, M20Doc said: In my experience the mounting for Grimes navigation lights (which you have) and Whelen, are the same. Clarence Martin: The Whelen mounting plate might only line up with 2 holes and a void for the 3rd. Nut plate may be required to align it at the proper angle as per instructions Quote Link to comment Share on other sites More sharing options...
OSUAV8TER Posted July 11, 2022 Report Share Posted July 11, 2022 5 minutes ago, KB4 said: Martin: The Whelen mounting plate might only line up with 2 holes and a void for the 3rd. Nut plate may be required to align it at the proper angle as per instructions Yours looks like it had a separate navigation and strobe light? There have been several iterations with this wingtip to include Hoskins, Grimes, and Whelen lights. Many different light configurations. As pictured previously, a WAT Orion 650E is a direct fit and shouldnt require drilling any new holes. Quote Link to comment Share on other sites More sharing options...
jaylw314 Posted July 11, 2022 Report Share Posted July 11, 2022 2 hours ago, OSUAV8TER said: Yours looks like it had a separate navigation and strobe light? There have been several iterations with this wingtip to include Hoskins, Grimes, and Whelen lights. Many different light configurations. As pictured previously, a WAT Orion 650E is a direct fit and shouldnt require drilling any new holes. I had the separate nav and strobe light, too. IIRC, my shop had to do something similar to mount it Quote Link to comment Share on other sites More sharing options...
