Montreal Posted May 9, 2022 Report Share Posted May 9, 2022 Curious if anyone uses mousemilk on turbo wastegate every 50hrs. Haven’t taken a look to see if that’s possible on Bravo. Came across this publication by Ram. https://www.ramaircraft.com/turbowastegates Quote Link to comment Share on other sites More sharing options...
kortopates Posted May 9, 2022 Report Share Posted May 9, 2022 You might be the only one that doesn’t - yet You want to apply it on the shaft of the waste gate at every oil change. It helps clean up harmful exhaust deposits that lead to the waste gate sticking. There really is no downside.Sent from my iPhone using Tapatalk 2 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted May 9, 2022 Report Share Posted May 9, 2022 https://mooneyspace.com/search/?q=Mousemilk&quick=1 high temperature lubrication… exhaust related… -a- 1 Quote Link to comment Share on other sites More sharing options...
thinwing Posted July 21, 2022 Report Share Posted July 21, 2022 apply it with an acid brush..bottom is harder to get to.Also place a wrench on flat parts of waste gate actuator next to spring and gently exercise shaft back and forth. 1 1 Quote Link to comment Share on other sites More sharing options...
