1 hour ago, Dave Taylor said:
Hi guys- Trying to help a friend with a 28v M20J.
 He says he needs a VR-802 voltage regulator, can’t find.
PMA replacement?  Didn’t see anything on Zeftronics.
 Thanks
His can be repaired. Call Don Maxwell
welcome aboard Dave…
+1 for Mr. Maxwell… because there are a few specialized VRs that need his kind of help…
Also call Zeftronics because they make really good VRs… and the M20J’s isn’t that special… is it? :)
My M20C got a new Zeftronics VR to keep its OH’d generator alive….
PP thoughts only, not a mechanic…
 Thanks
I went through this two years ago, also with a 28V M20J (MSE).  I spent a fair amount of time tracking down all possible leads and the final determination was: the original Mooney-branded part is no longer made and I could not find any in stock or from salvage.  The choice was simple: either buy a 1+ AMU retrofit kit to replace the original V/R with a more readily available part already used in other models, or, send to Maxwell for IRAN for quite a bit less.  I chose the latter, no problems since.
  • 1 year later...
