have you tried the flashlight trick?  if you shine a light at the screen kind of from the side, you may be able to see the numbers.  not a long term solution but it seems to work, at least for a while.
Hey! A Banjo sighting!!!
Last time I saw Banjo, I was with @Alan Fox… cruising around KOSH….
Alan may have insight for screen fixes for the KX155…
There are also replacement LCD screens mentioned around here every now and then… nice upgrade, but not low cost.
Banjo , sorry I havent returned the call , Send the radio , To C&W Aero services , 19 Wright Way STE 3, Fairfield, NJ 07004   C/O Alan Fox
