PT20J Posted November 12, 2021 Report Share Posted November 12, 2021 I finally got a reasonably good shot of the new panel. It's all done except for the Smart Glide button which is back ordered. But no problem because I understand that the G3X Touch Smart Glide software has slipped from late this year to Q1 or Q2 next year. A few comments on choices that might not be obvious. The iPad mini is powered by a USB charger mounted behind the panel. I moved the alternate static source valve/knob to the left because I find the most convenient place to stow the headset is on control shaft behind the yoke and the old knob placement was in the way. I added the AV-20-S as a tie breaker in the event of a G3X/G5 miscompare. I mounted it high in case the AoA indication proves to be useful (I don't have high hopes for it -- I never could get the Aspen AoA to be very accurate). I already had the GTX 345. I decided to replace the KX 165 (which worked fine) with a GNC 255 just for increased reliability/maintainability over the next ten years. The EDM 700 was in the center console next to the trim/flap indicators so removing it left a hole which I plugged with a Guardian CO detector. I only have a few hours on it -- mostly checking stuff out. It's all working fine and the autopilot seems rock solid. I really like the EIS and especially the position of the engine gauges next to the attitude display. Skip 16 Quote Link to comment Share on other sites More sharing options...
RoundTwo Posted November 12, 2021 Report Share Posted November 12, 2021 Wow, I’m sure I’ll only be the first to tell you what an awesome panel that is. Beautifully simple looking. We’ve all get panel envy! Great job! R2 Quote Link to comment Share on other sites More sharing options...
rbridges Posted November 12, 2021 Report Share Posted November 12, 2021 Very clean and functional. It literally looks like it could have rolled off the factory assembly line. Quote Link to comment Share on other sites More sharing options...
cbarry Posted November 12, 2021 Report Share Posted November 12, 2021 That’s a really nice panel layout! I really like how you went with the 650 versus a 750 which others do fine, but it ends up needing remote this and remote that to not look like an overcrowded panel. Great Job! 1 Quote Link to comment Share on other sites More sharing options...
eman1200 Posted November 12, 2021 Report Share Posted November 12, 2021 nice panel! is the gi275 compatible with the g3x or do u have to use the g5? Quote Link to comment Share on other sites More sharing options...
PT20J Posted November 12, 2021 Author Report Share Posted November 12, 2021 1 hour ago, eman1200 said: nice panel! is the gi275 compatible with the g3x or do u have to use the g5? Garmin allows the GI 275 as a backup to the G3X, but it is not as well integrated as the G5 because the G3X and G5 use CAN bus architecture whereas the GI 275 uses ARINC 429 and HSDB (Ethernet). Skip 2 Quote Link to comment Share on other sites More sharing options...
EricJ Posted November 12, 2021 Report Share Posted November 12, 2021 Very nice! It looks like your effort is gonna pay off. Quote Link to comment Share on other sites More sharing options...
201Mooniac Posted November 12, 2021 Report Share Posted November 12, 2021 Absolutely beautiful panel! I'm sure you'll enjoy it. Quote Link to comment Share on other sites More sharing options...
bmcconnaha Posted November 21, 2021 Report Share Posted November 21, 2021 On 11/11/2021 at 9:10 PM, PT20J said: I finally got a reasonably good shot of the new panel. It's all done except for the Smart Glide button which is back ordered. But no problem because I understand that the G3X Touch Smart Glide software has slipped from late this year to Q1 or Q2 next year. A few comments on choices that might not be obvious. The iPad mini is powered by a USB charger mounted behind the panel. I moved the alternate static source valve/knob to the left because I find the most convenient place to stow the headset is on control shaft behind the yoke and the old knob placement was in the way. I added the AV-20-S as a tie breaker in the event of a G3X/G5 miscompare. I mounted it high in case the AoA indication proves to be useful (I don't have high hopes for it -- I never could get the Aspen AoA to be very accurate). I already had the GTX 345. I decided to replace the KX 165 (which worked fine) with a GNC 255 just for increased reliability/maintainability over the next ten years. The EDM 700 was in the center console next to the trim/flap indicators so removing it left a hole which I plugged with a Guardian CO detector. I only have a few hours on it -- mostly checking stuff out. It's all working fine and the autopilot seems rock solid. I really like the EIS and especially the position of the engine gauges next to the attitude display. Skip Skip, question for you on the smart glide. If you have an XI, and a GFC500, the smart glide will still work, correct? Quote Link to comment Share on other sites More sharing options...
PT20J Posted November 21, 2021 Author Report Share Posted November 21, 2021 36 minutes ago, bmcconnaha said: Skip, question for you on the smart glide. If you have an XI, and a GFC500, the smart glide will still work, correct? As I understand it, Smart Glide requires the GFC 500 software in the G3X to support it and that is not yet available. Quote Link to comment Share on other sites More sharing options...
Baker Avionics Posted November 24, 2021 Report Share Posted November 24, 2021 On 11/20/2021 at 10:05 PM, PT20J said: As I understand it, Smart Glide requires the GFC 500 software in the G3X to support it and that is not yet available. Bryan and Skip, see below from Garmin: Smart Glide support with a variety of Garmin systems In certified aircraft, Smart Glide will become available with a GTN Xi series navigator paired with a compatible Garmin flight display including the G500 TXi™/G600 TXi, GI 275 electronic flight instrument, the G3X Touch™, or G5 electronic flight instrument, with others to be added later4. Compatible Garmin autopilots such as GFC 500 or GFC 600 can be automatically engaged when Smart Glide is activated5. For aircraft without a compatible Garmin autopilot, Smart Glide will still provide critical information and features to help manage engine emergencies and help to reduce pilot workload. Further, experimental aircraft with G3X Touch and a G3X autopilot can also enable Smart Glide technology when appropriately equipped. 1 2 Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted November 24, 2021 Report Share Posted November 24, 2021 You could put a ginormous glove box on the right side. Who couldn't use more storage? 1 Quote Link to comment Share on other sites More sharing options...
ZuluZulu Posted December 2, 2021 Report Share Posted December 2, 2021 @PT20J In your planning did you explore altering the structure behind the panel? For example, what if I want my GTN 750 radio stack a few inches farther to the right? Or I just don't want to be bound by the original design? I assume this is very expensive and probably inadvisable but I'm curious if you considered it. Quote Link to comment Share on other sites More sharing options...
PT20J Posted December 2, 2021 Author Report Share Posted December 2, 2021 1 minute ago, ZuluZulu said: @PT20J In your planning did you explore altering the structure behind the panel? For example, what if I want my GTN 750 radio stack a few inches farther to the right? Or I just don't want to be bound by the original design? I assume this is very expensive and probably inadvisable but I'm curious if you considered it. I didn’t investigate that because I could make everything fit as originally designed. If I moved the radio stack in my plane, the hump in the glare shield would be in the wrong place. Skip 1 Quote Link to comment Share on other sites More sharing options...
