Robert67 Posted August 17, 2021 Report Share Posted August 17, 2021 Can someone tell me if the square metal part of the hanger is supposed to be loose and floating or does the metal block mount rigidly to the firewall? Thanks Quote Link to comment Share on other sites More sharing options...
Shadrach Posted August 17, 2021 Report Share Posted August 17, 2021 (edited) Should float. Edited August 17, 2021 by Shadrach 2 Quote Link to comment Share on other sites More sharing options...
Robert67 Posted August 17, 2021 Author Report Share Posted August 17, 2021 Thanks 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted August 18, 2021 Report Share Posted August 18, 2021 With one bolt, and being off center to the bracket bolt’s centerline… There isn’t much choice but to float… Oddly, the aluminum block looks a lot like the ones used for the engine mounts… but with four mounting bolts, the engine is held pretty much in one place… no floating… See if @M20Doc is cruising by… (exhaust hanger mount rigidity question) Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Guest Posted August 18, 2021 Report Share Posted August 18, 2021 Both holes in the aluminum block have steel bushings, suggesting that the block and bracket are meant to be free to rotate. Clarence Quote Link to comment Share on other sites More sharing options...
carusoam Posted August 18, 2021 Report Share Posted August 18, 2021 Good Morning Doc! -a- Quote Link to comment Share on other sites More sharing options...
Guest Posted August 18, 2021 Report Share Posted August 18, 2021 You’re up early! Clarence Quote Link to comment Share on other sites More sharing options...
