DXB Posted August 20, 2021 Author Report Posted August 20, 2021 3 hours ago, ShuRugal said: Where's the oil cooler? Sent from my Pixel 3a using Tapatalk bottom left of front cowl - hmmm interesting point - I wonder if a winterization plate in the winter would reduce the difference between sides of the engine…. Quote
mike20papa Posted August 21, 2021 Report Posted August 21, 2021 An inherent baffle seal problem with 180 hp Mooneys - especially if they are equipped with a light weight starter and alternator upgrade - is shown in this photo. The seal around the oil feed line for the prop governor especially challenging. Yes, the photo loaded inverted. Quote
carusoam Posted August 22, 2021 Report Posted August 22, 2021 Great pic Papa! Fantastic orientation 47U! Great High tech alternator and starter upgrades…. Best regards, -a- Quote
Michael Leighton Posted July 7, 2023 Report Posted July 7, 2023 I put all new cylinders on my C last October. Since then CHT’s bouncing off 450 on takeoff and climb out. Months of trouble shooting. Only minor improvements after doing all of the usual things. Sealed the dog house so tight you could bury an Egyptian king in there. Not much better. Then I had a starter fail. Pulled the old starter but the new one was a different shape so I had to fabricate a new front baffle. While I was in there I discovered that there was a significant air leak at the oil cooler to cowling dispite a new gasket. Fixed that and fabricated a better deflector baffle behind the oil cooler taking the oil cooler air to the left cowl flap- which is now rigged at 1.1 inches when CLOSED. Lastly, I reenforced the baffling where it fits int the lower channel of the cowl because I found two spots where it flexed enough to come out of the channel under high aerodynamic pressure. Test flight conditions- 92F and 3000 ft density altitude. I hit 404 on number 4 in a prolonged full power WOT climb at 120 mph to 3000 feet AGL. 71 percent power and approx. 10gph yielded the numbers you see on my JPI. 2 Quote
