JoeM Posted July 26, 2021 Report Share Posted July 26, 2021 Would appreciate guidance how to remove PC rudder servo that sits under the battery. Search forums without success. Looks like the back nut is inside the belly pan....Correct? Thanks..... Quote Link to comment Share on other sites More sharing options...
0TreeLemur Posted July 26, 2021 Report Share Posted July 26, 2021 1 hour ago, JoeM said: Would appreciate guidance how to remove PC rudder servo that sits under the battery. Search forums without success. Looks like the back nut is inside the belly pan....Correct? Thanks..... Yes. Access through the belly. Do you have elevator servos? If so, I'm interested & looking for a spare set with intact membranes. Quote Link to comment Share on other sites More sharing options...
JoeM Posted July 26, 2021 Author Report Share Posted July 26, 2021 Thanks... I am too Quote Link to comment Share on other sites More sharing options...
