MooneyBe Posted May 31, 2021 Report Share Posted May 31, 2021 Oxygen topics must be in the air! Dad jokes aside, does anyone have a recommendation on where to purchase just the Scott fitting that will fit a constant flow tube (like an Aerox or MountainHigh constant flow)? Aircraft Spruce has the "Retrofit kit plus Scott type fitting" (#13-18992 here https://www.aircraftspruce.com/catalog/pspages/retrofit.php) but I really only need the fitting itself and don't want to drop $105 on a 1 inch piece of brass, though 0.1 AMU to ensure oxygen flows is probably fine if it comes down to it (Other relevant thread on this topic pasted below for anyone that ends up here because of a search for "oxygen" or "Scott fitting".) B Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted May 31, 2021 Report Share Posted May 31, 2021 (edited) 1 hour ago, MooneyBe said: Oxygen topics must be in the air! Dad jokes aside, does anyone have a recommendation on where to purchase just the Scott fitting that will fit a constant flow tube (like an Aerox or MountainHigh constant flow)? Aircraft Spruce has the "Retrofit kit plus Scott type fitting" (#13-18992 here https://www.aircraftspruce.com/catalog/pspages/retrofit.php) but I really only need the fitting itself and don't want to drop $105 on a 1 inch piece of brass, though 0.1 AMU to ensure oxygen flows is probably fine if it comes down to it (Other relevant thread on this topic pasted below for anyone that ends up here because of a search for "oxygen" or "Scott fitting".) B https://www.mhoxygen.com/product/bnc-adapter/https://www.aviationoxygen.com/oxygen-mask-connectors/ Edited May 31, 2021 by N201MKTurbo 1 Quote Link to comment Share on other sites More sharing options...
