robert7467 Posted May 22, 2021 Report Posted May 22, 2021 Just checking to see if this the the proper way to secure the cable to the prop governor. The mechanic seems cool with it, but something just seems off about it. I have seen plenty of things that seem off, but they are proper. Just double checking on this one! Quote
flyingchump Posted May 22, 2021 Report Posted May 22, 2021 The photo is a bit close up but mine looks pretty close to that. Both my clamps are straight tho. I had a reputable shop install a new pcu5000 a few months back so I and some confidence they did it right.... Quote
Guest Posted May 22, 2021 Report Posted May 22, 2021 That’s not correct. The clamps are supposed to have no rubber inserts. Clarence Quote
robert7467 Posted May 23, 2021 Author Report Posted May 23, 2021 I guess it's correct! Thank you for the clarification! Quote
N201MKTurbo Posted May 23, 2021 Report Posted May 23, 2021 I usually use non-cushioned clamps and then lock wire the gap in the cable around the clamp. Quote
