Costa Leite Posted April 29, 2021 Report Share Posted April 29, 2021 Dear Mooniacs I recently realized that the GTN 750 in our M20J Allegro has another problem, probably since installation. Only now I noticed that the basic Terrain Awareness System is not working at all, because I never heard the initial message after system self-test on power up "TAWS System OK". And neither I saw or heard any basic Terrain Awareness warning message when we fly close to obstacles or mountain terain. I have a valid terrain and obstacle database, and I do see contours terrain colours overlay, and obstacle colours symbols overlay, on map page or terrain page. But if get close to any terrain or obstacle i don’t receive any warning message, neither visual nor aural. And I do see a Terrain Awareness message on iPad or iPhone when flying close to antenas, etc.. I think I must have any error on my GTN configuration... What kind of information should I try to find on GTN pages to clarify this situation? Anyguides for troubleshooting? Does anyone have any clue on the reason of this situaion, and how to solve it? Many thanks in advance for your help. Cheers Fredi Quote Link to comment Share on other sites More sharing options...
flyboy0681 Posted April 29, 2021 Report Share Posted April 29, 2021 TAWS is an optional feature. Did you purchase it for the unit? Quote Link to comment Share on other sites More sharing options...
201Mooniac Posted April 29, 2021 Report Share Posted April 29, 2021 Are you expecting TAWS or just terrain awareness. If TAWS, as was said it is an optional feature. Terrain awareness can be enabled in setup. If you aren't hearing "Terrain System Test Okay" on startup, either the audio isn't wired up or the terrain awareness system isn't enabled. Quote Link to comment Share on other sites More sharing options...
carusoam Posted April 30, 2021 Report Share Posted April 30, 2021 Seeing if @KLudwick s flying by this thread... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
PeteMc Posted April 30, 2021 Report Share Posted April 30, 2021 Is there anyplace you can legally fly low? We have a route along the shoreline just south of JFK under the CBA at or below 500ft. When I first start dropping down I'm still far enough away from JFK that I will get a "TERRAIN" warning. As you get closer to JFK it goes away because the GTN recognized I'm near an airport. So if you can drop down below 500ft someplace AWAY from an airport, you should get the warning. Don't dive down, but descend at least at 500+ FPM, as you get down there the alerts should start going off. Also, if you fly with ForeFlight or Garmin Pilot and have gotten the warning on your iPad, but not on the GTN, then there is a problem. Quote Link to comment Share on other sites More sharing options...
Costa Leite Posted April 30, 2021 Author Report Share Posted April 30, 2021 I am just expecting terrain and obstacle awareness, and not TAWS. I know that I need to buy an optional feature for TAWS-B or TAWS-A, but that’s not what I am looking for. I just want to have basic terrain and obstacle awareness, but I am not having that... I think this is something wrong with the setup Quote Link to comment Share on other sites More sharing options...
PeteMc Posted April 30, 2021 Report Share Posted April 30, 2021 So when flying around you should see black or maybe some yellow. If you get closer to terrain (mountain tops) it should show red. But you will not hear or see any warnings. If you get really close to something OR the GTN calculates that you're closing on terrain, it will give you a screen warning and if connect to your audio panel, you'll get an audio warning too. Closing in on terrain can be straight at something, not climbing fast enough (which is really straight into something) or descending. HOWEVER, if you're near an airport, you will not get the alerts as you descend to land. (Wouldn't that be a pain!) So in my example, if you can descend at a pretty good rate (you don't need to go out of the normal envelope), you should get a warning. And KNOW the area so there are no tower wires, etc. 1 Quote Link to comment Share on other sites More sharing options...
PT20J Posted April 30, 2021 Report Share Posted April 30, 2021 Did you go to the menu for the terrain app and check that Terrain Inhibit is not selected? You can also manually ground test the system from this page. Skip Quote Link to comment Share on other sites More sharing options...
Costa Leite Posted April 30, 2021 Author Report Share Posted April 30, 2021 (edited) I do not receive any message at start up like “Terrain System OK”, neither do I receive any visual warning or aural warning message for terrain or obstacle or GP deviation. But I do receive visual and aural message for traffic warning. So I believe this is not a audio wiring problem from GTN to audiopanel because if it was I wouldn’t get any other aural warning like the traffic warnings call outs, and I would see the visual terrain warning message, right? According to GTN manual, on the Terrain App page, on the setup settings, if the Inhibit is selected it will be automatically disabled on next power up. In my opinion it seems that my GTN has a somehow permanent inhibit terrain warning... is this possible? Where can I check it? Edited April 30, 2021 by Costa Leite Quote Link to comment Share on other sites More sharing options...
jetdriven Posted May 1, 2021 Report Share Posted May 1, 2021 The GTx345 gives the audio traffic alerts. the GTN terrain alerts come from that box. Quote Link to comment Share on other sites More sharing options...
PT20J Posted May 1, 2021 Report Share Posted May 1, 2021 I believe that the terrain annunciations require an unswitched input to the audio panel. It’s possible that isn’t connected or you may have run out of unswitched inputs. You could check the configuration by prowling around the configuration mode — hold the Home button while applying power and release it when the Garmin logo appears. Maybe @Baker Avionics Greg has some suggestions. Skip Quote Link to comment Share on other sites More sharing options...
201Mooniac Posted May 3, 2021 Report Share Posted May 3, 2021 If you aren't getting any messages on the GTN, go into setup mode, go to Terrain, and make sure Terrain Alerting is enabled. Quote Link to comment Share on other sites More sharing options...
PT20J Posted May 3, 2021 Report Share Posted May 3, 2021 1 hour ago, 201Mooniac said: If you aren't getting any messages on the GTN, go into setup mode, go to Terrain, and make sure Terrain Alerting is enabled. I’m still learning this thing. Did you mean the GTN Setup Page in Configuration Mode? I see a place there where you set up the audio for alerts and you can set the volume 0 - 100% with zero being muted. Skip Quote Link to comment Share on other sites More sharing options...
201Mooniac Posted May 3, 2021 Report Share Posted May 3, 2021 Oops, sorry, I meant the GTN Options page in configuration mode. It should include a Terrain option that takes you to the option to enable Terrain Alerting. If you can't find it, PM me. 1 Quote Link to comment Share on other sites More sharing options...
Vance Harral Posted May 4, 2021 Report Share Posted May 4, 2021 What revision of software are you running in your GTN? The non-TAWS, Terrain Alerting System, was introduced in software revision 5.00. If the software in your GTN is older than that, it won't have the Terrain Alerting System feature. 1 Quote Link to comment Share on other sites More sharing options...
Costa Leite Posted May 4, 2021 Author Report Share Posted May 4, 2021 (edited) Thanks for all comments. I am almost sure that this is a setup problem and not a alert audio wiring problem because I do receive other audio messages from GTN and, most important, besides not having aural messages for basic Terrain Awareness I don’t receive any Terrain Awareness visual messages on display either as I do receive on iPad on GarminPilot. The GTN750 main software was originally V6.21 and it was upgraded to V6.70 last summer. The picture in attach shows that my GTN options menu on the Terrain page aren’t as they should be according to GTN Pilots Guide, because I believe I should have a temporary Inhibit Terrain Awareness button, but that’s not the case currently. So I am really thinking this is a setup problem and will investigate on Configuration Mode as suggested. Edited May 4, 2021 by Costa Leite 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted May 4, 2021 Report Share Posted May 4, 2021 See if this helps any? -a- 1 Quote Link to comment Share on other sites More sharing options...
PT20J Posted May 4, 2021 Report Share Posted May 4, 2021 The installation manual isn’t available except to dealers, but there is some configuration info in the maintenance manual which can be downloaded from Garmin’s website. https://static.garmin.com/pumac/190-01007-c1_01.pdf Maybe by the time I get mine installed, I’ll understand this thing 1 Quote Link to comment Share on other sites More sharing options...
PeteMc Posted May 4, 2021 Report Share Posted May 4, 2021 And is there any terrain near by? My screen would be back at 5080 flying around my airport. Quote Link to comment Share on other sites More sharing options...
Costa Leite Posted May 4, 2021 Author Report Share Posted May 4, 2021 Of course that I am trying to get terrain warnings when flying (very) close terrain or obstacle. Already explained above that on these situations GarminPilot gives the Terrain Warning, but nothing happens on GTN... Quote Link to comment Share on other sites More sharing options...
Rmag Posted May 5, 2021 Report Share Posted May 5, 2021 It’s a setting in the configuration menu which is normally set up by a dealer. You can get in there yourself by holding the home button in when you boot up. You can screw things up if you don’t know what you are doing in there though so beware. There is a switch between Terrain Proximity and Terrain Alerting. If you have another device like a G500 TXi that provides the Terrain Alerts you set the GTN to Terrain Proximity so you don’t get double alerts. if you don’t have another device that gives the terrain alerts you set the GTN to Terrain Alert. In the config menu it is: GTN Options/Terrain/Terrain Alerting 1 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted May 5, 2021 Report Share Posted May 5, 2021 Great support RMag! Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Costa Leite Posted May 5, 2021 Author Report Share Posted May 5, 2021 Many thanks RMag for the help! I will give feedback later as soon as I get again on board. Quote Link to comment Share on other sites More sharing options...
Costa Leite Posted May 17, 2021 Author Report Share Posted May 17, 2021 I finally had the time to adjust the configuration of the GTN750. I confirmed that the avionics shop left the GTN Terrain options on the TerrainProximity selection, and as we don't have any other display for Terrain Warnings, it was wrongly configurated and we weren't getting any terrain message at all. So, I reset the Terrain Options to TerrainAlerting, and now everything is working just fine! I finally get initial message "Terrain System OK", and also the Terrain Warnings, and the "500'" callout. On next flights I will try to get the warning message for steep descents. Thanks to all for your help, and specially to RMag that cleared gave the solution, avoiding me to spend time and money on a travel to avionics maintenance with a shop that should have left this working since day one. In attach you can see the videos of the reconfiguration, and the terrain alerts I now get as a renewed happy costumer of GTN750 IMG_3622.MP4 IMG_3729.MP4 4 Quote Link to comment Share on other sites More sharing options...
carusoam Posted May 18, 2021 Report Share Posted May 18, 2021 Wow! Great follow-up Costa! Fantastic Pirep for @Rmag! Wonderful videos! Great to see things working well! Best regards, -a- 1 Quote Link to comment Share on other sites More sharing options...
