Guest Posted November 11, 2021 Report Share Posted November 11, 2021 1 hour ago, Airways said: We narrowed it down to adjusting the righthand aileron trim tab. My question now is: does the aileron trim tab require equal bending over the whole span or do you just bend the outboard part ? The reason I ask is because it seems hard to bend the whole aileron trim tab at once over the whole span. The book says to use 3” wide vice grip pliers to bend the trailing edge, I’ve never done it this way. I clamp two pieces of 1 x2 pine over the trailing edge and bend the entire surface a very small amount. The book also says to only Ben the trailing edge down. Make sure you’re bending the correct aileron. Clarence Quote Link to comment Share on other sites More sharing options...
Airways Posted November 11, 2021 Author Report Share Posted November 11, 2021 18 minutes ago, M20Doc said: I clamp two pieces of 1 x2 pine over the trailing edge and bend the entire surface a very small amount. Isn’t it hard to get/feel feedback by using two pieces of pine ? How can you tell how much you bend the trailing edge before actually removing the pine and looking at the result ? Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted November 11, 2021 Report Share Posted November 11, 2021 2 hours ago, Airways said: Isn’t it hard to get/feel feedback by using two pieces of pine ? How can you tell how much you bend the trailing edge before actually removing the pine and looking at the result ? Even looking at it won't tell you much. If you bend the whole trailing edge, the bend will hard to see. It is mostly by feel. If you are narcotic enough, you can drill holes where the rivets are so the boards clamp tight on the edge. Quote Link to comment Share on other sites More sharing options...
Airways Posted November 11, 2021 Author Report Share Posted November 11, 2021 Sounds like I’m in need of a plane whisperer ! Quote Link to comment Share on other sites More sharing options...
PT20J Posted November 11, 2021 Report Share Posted November 11, 2021 5 hours ago, Airways said: We narrowed it down to adjusting the righthand aileron trim tab. My question now is: does the aileron trim tab require equal bending over the whole span or do you just bend the outboard part ? The reason I ask is because it seems hard to bend the whole aileron trim tab at once over the whole span. You should bend the entire span since that will require less deflection and be unnoticeable. You can do a short section at a time and work your way along the length. You should only need to deflect it a tiny amount. Skip Quote Link to comment Share on other sites More sharing options...
Airways Posted November 11, 2021 Author Report Share Posted November 11, 2021 Thank you, Skip. Yes, then it would make sense to work with a pine or aluminium profile in order to bend all in one move. Quote Link to comment Share on other sites More sharing options...
