Hopsl Posted March 19, 2021 Report Share Posted March 19, 2021 (edited) Does anyone have a part number and or know where to buy the seat adjustment bar for the passenger seat on an 87 M20J? Looks like someone stepped on ours, many times, and it's now keeping the pins from seating deep enough in the tracks. 63786356798__72539780-4526-4E9D-B1FC-5F06F9F6A2CA.heic thanks for any help Edited March 19, 2021 by Hopsl Quote Link to comment Share on other sites More sharing options...
carusoam Posted March 20, 2021 Report Share Posted March 20, 2021 For Mooney specific parts dial Dan at Lasar... For pre-flown Mooney parts.... @Alan Fox @Jerry Pressley @SheryLoewen -a- 1 Quote Link to comment Share on other sites More sharing options...
Hopsl Posted March 20, 2021 Author Report Share Posted March 20, 2021 Thank you Quote Link to comment Share on other sites More sharing options...
flyboy0681 Posted March 21, 2021 Report Share Posted March 21, 2021 On 3/19/2021 at 1:48 PM, Hopsl said: Does anyone have a part number and or know where to buy the seat adjustment bar for the passenger seat on an 87 M20J? Looks like someone stepped on ours, many times, and it's now keeping the pins from seating deep enough in the tracks. 63786356798__72539780-4526-4E9D-B1FC-5F06F9F6A2CA.heic 1.75 MB · 22 downloads thanks for any help I'm having the same issue too. How does the bar prevent the pins from seating? Quote Link to comment Share on other sites More sharing options...
Hopsl Posted March 21, 2021 Author Report Share Posted March 21, 2021 When the seat is full aft, the pins are riding on the top of the seat track. In that position, they hold the adjustment bar slightly elevated. Where the pins attach to the bar now becomes the fulcrum or pivot point for any down pressure on the front of that bar. If the bar is slightly bent around that fulcrum, the pins are held slightly high when seated in the tracks. Once the bar is repaired or replaced, a fix for this would be to drill holes in the track, at the full aft position, so the pins would be fully seated and the seat locked to the rear. Quote Link to comment Share on other sites More sharing options...
flyboy0681 Posted May 5, 2021 Report Share Posted May 5, 2021 On 3/21/2021 at 3:19 PM, Hopsl said: When the seat is full aft, the pins are riding on the top of the seat track. In that position, they hold the adjustment bar slightly elevated. Where the pins attach to the bar now becomes the fulcrum or pivot point for any down pressure on the front of that bar. If the bar is slightly bent around that fulcrum, the pins are held slightly high when seated in the tracks. Once the bar is repaired or replaced, a fix for this would be to drill holes in the track, at the full aft position, so the pins would be fully seated and the seat locked to the rear. Exactly what happened to my right hand seat, the bar was bent. I got it fix during the annual but was told that I need a new one. Has anybody responded to you on where to obtain one? My A&P tried the factory and Lasar, but no joy. Quote Link to comment Share on other sites More sharing options...
Guest Posted May 5, 2021 Report Share Posted May 5, 2021 I believe that I have a new one in stock. I’ll check tomorrow. Clarence Quote Link to comment Share on other sites More sharing options...
flyboy0681 Posted May 6, 2021 Report Share Posted May 6, 2021 21 hours ago, M20Doc said: I believe that I have a new one in stock. I’ll check tomorrow. Clarence Were you able to check? Quote Link to comment Share on other sites More sharing options...
Guest Posted May 6, 2021 Report Share Posted May 6, 2021 57 minutes ago, flyboy0681 said: Were you able to check? I have a new 140215-029. Clarence Quote Link to comment Share on other sites More sharing options...
mikey757 Posted March 8, 2023 Report Share Posted March 8, 2023 Hello Doc, Do you still have this Bar, 140215-029, this is exactly what I need now. Thanks, Mike Quote Link to comment Share on other sites More sharing options...
Fly Boomer Posted March 8, 2023 Report Share Posted March 8, 2023 9 hours ago, mikey757 said: Hello Doc, Do you still have this Bar, 140215-029, this is exactly what I need now. Thanks, Mike He is not likely to accidently run across this post to a topic that was last active a year ago unless you do something to get his attention like this: @M20Doc Mikey looking for a part. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 8, 2023 Report Share Posted March 8, 2023 10 hours ago, mikey757 said: Hello Doc, Do you still have this Bar, 140215-029, this is exactly what I need now. Thanks, Mike I think I may still have one. Email my wife tomorrow, maureen@tricityaero.com Quote Link to comment Share on other sites More sharing options...
flyboy0681 Posted March 8, 2023 Report Share Posted March 8, 2023 8 minutes ago, M20Doc said: I think I may still have one. Email my wife tomorrow, maureen@tricityaero.com I think I bought it from you soon after your original post. Quote Link to comment Share on other sites More sharing options...
