cliffy Posted February 18, 2021 Report Share Posted February 18, 2021 I have used up all my knowledge trying to find the part numbers for the fuel quantity gauges in my 64 M20D. Maybe its the weather or the line up of the stars but I just can't find them (both the same I presume) I'm usually pretty good at this stuff but this one has me lost in space (even MooneySpace and Goog search) I want to get overhaul/exchange units for next weeks annual (mine have developed a "stickyness" in the needles) and I don't want to have to wait for the old ones to come out and then have to overnight everything to get them overhauled. I found the cluster gauge unit number but not the individual gauge P/N. Anyone got any ideas? They are the 156 lb gauges (26 gallon tanks). Standing by to repel boarders! :-) Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted February 18, 2021 Report Share Posted February 18, 2021 Not sure if anyone sells new ones of the old technology. You can upgrade to digital sensors or overhaul the old ones. Quote Link to comment Share on other sites More sharing options...
Raymond J1 Posted February 18, 2021 Report Share Posted February 18, 2021 The original manufacturer is Garwin Carruth, who sold this branch of digital instrumentation in the 80s and still exists under the name Sigma tek. The garwin" gauge cluster " is no longer manufactured nowadays but the plug-in indicators in this cluster are still available. These are the cluster gauges reference 169 L of which here is the link. For volume gauges, they are adjustable according to the resistance of the sensors and the graduations are either interchangeable with your model or to be specified in your order of new gauges. http://www.sigmatek.com/cluster_gauges.html 2 2 Quote Link to comment Share on other sites More sharing options...
cliffy Posted February 18, 2021 Author Report Share Posted February 18, 2021 I've got a supplier who has overhauled units but needs the original p/n to check stock for me A p/n I can't find until I get the cluster out, which I don't want to wait that long. Quote Link to comment Share on other sites More sharing options...
markgrue Posted February 18, 2021 Report Share Posted February 18, 2021 Perhaps Alan Fox has one laying around and can look at the part number real quick... Mark Quote Link to comment Share on other sites More sharing options...
Nokomis449 Posted February 18, 2021 Report Share Posted February 18, 2021 Hopefully this'll help as it sounds like we have the same cluster. As-removed from my 1968 G at last annual, replaced with an EDM900. EDM 900 pic included to show that it's a near-perfect fit where the original cluster goes. All gauges were working when removed and I plan on listing the whole set for sale along with the working as-removed fuel pressure/manifold pressure gauge. Engine is a Lycoming O-360-A1D, 26 gal tanks. The individual fuel gauges have different part numbers and different electrical connections as one is male, one is female (see pics). If you want to verify part numbers, the individual gauges can be easily removed from the front by unscrewing the single screw holding it until the screw is loose, then pull on the screw itself to slide out the instrument. The left fuel gauge shows a stamped date of Mar 6 1968, with an additional stamped date of Oct 11 2002 which I assume is a rebuilt/refurbished? date. The right fuel gauge has a handwritten sticker on it covering the original stamps and I know not what it means. 1 2 Quote Link to comment Share on other sites More sharing options...
201Steve Posted February 19, 2021 Report Share Posted February 19, 2021 The fact that FAA hasn’t made certification for modern engine gauges a simple process is one of the most frustrating things. Lose attitude indication- might die. Lose airspeed indication, might die. Auto pilot malfunction/trim, might die. Lose RPM reading, shrug shoulders and fix as soon as practical. Lose fuel level, same. Lose MP, same. Lose oil pressure, cautiously land. WTF? EDM 830- not certified. Insight products, etc etc. Tell me those aren’t as good as the trash still existing in the retro fleet. I’ll wait. 3 1 Quote Link to comment Share on other sites More sharing options...
cliffy Posted February 20, 2021 Author Report Share Posted February 20, 2021 NOKOMIS Thank you Just what I needed for numbers Quote Link to comment Share on other sites More sharing options...
carusoam Posted February 20, 2021 Report Share Posted February 20, 2021 Go MS! -a- Quote Link to comment Share on other sites More sharing options...
cliffy Posted February 20, 2021 Author Report Share Posted February 20, 2021 On 2/19/2021 at 2:25 PM, 201Steve said: EDM 830- not certified. Insight products, etc etc. Tell me those aren’t as good as the trash still existing in the retro fleet. I’ll wait. No they aren't as good - THEY ARE WAY BETTER!!!!!!! 1 Quote Link to comment Share on other sites More sharing options...
MB65E Posted February 20, 2021 Report Share Posted February 20, 2021 The Early insight/GEM line was a little silly. I really like my G2 I installed. Kinda a no brainer for the money. -Matt Quote Link to comment Share on other sites More sharing options...
201Steve Posted February 20, 2021 Report Share Posted February 20, 2021 38 minutes ago, MB65E said: The Early insight/GEM line was a little silly. I really like my G2 I installed. Kinda a no brainer for the money. -Matt I have a G2 as well. Great product. Quote Link to comment Share on other sites More sharing options...
cliffy Posted February 23, 2021 Author Report Share Posted February 23, 2021 Unfortunately I don't have the same gauges shown above. I have the early model that has all the gauges in one block and not individually separable with the 1 screw each so I'll have to send the entire engine instrument block out to fix the fuel level gauges. It does look like they do have a trim screw for setting and maybe AP of LH will have the info I need to trim them in place when they get back. . 1 Quote Link to comment Share on other sites More sharing options...
Nokomis449 Posted February 23, 2021 Report Share Posted February 23, 2021 Sorry to hear that. Is the connection on the back the same as mine (pic above)? If the overhaul/repair price is very much I'd be willing to ship these to you for a test fit and tryout, and if you like them I'll sell them at a very reasonable price. I'd rather them be installed somewhere being useful, rather than collecting dust on a shelf. All gauges were working when removed, with the two fuel gauges being somewhat low on their readings. The new EDM900 shows the same fuel gauge wonkiness, so I assume it's the fuel senders. And I highly recommend the EDM900 to replace the whole instrument sixpak. It's a near-perfect fit (pic above), and I really appreciate the fact that I can download and store data from every flight and even (for free!) upload the data to Savvy's website and view my data in the same charts Savvy uses for their data analysis. I had it installed with the engine overhaul and don't have a breakdown of the install labor, but I'd guess the hardware was around $2k (with fuel sender, carb temp, and 2 tanks) and install was probably another $2-3k. 3 Quote Link to comment Share on other sites More sharing options...
carusoam Posted February 24, 2021 Report Share Posted February 24, 2021 Today’s Awesome MSer award goes Nokomis! Fantastic details shared. Best regards, -a- Quote Link to comment Share on other sites More sharing options...
cliffy Posted February 24, 2021 Author Report Share Posted February 24, 2021 Although the 900 is nice it retails for around $4800 not counting install labor. PO of my airplane put in an EI oil temp/oil press gauge and blocked the six pac ones and my ammeter is a load meter (+ amps only) instead of a true amp gauge like yours so your six pac would need work arounds for my install but thanks for the offer. That was nice of you. Quote Link to comment Share on other sites More sharing options...
jaylw314 Posted February 24, 2021 Report Share Posted February 24, 2021 47 minutes ago, cliffy said: Although the 900 is nice it retails for around $4800 not counting install labor. PO of my airplane put in an EI oil temp/oil press gauge and blocked the six pac ones and my ammeter is a load meter (+ amps only) instead of a true amp gauge like yours so your six pac would need work arounds for my install but thanks for the offer. That was nice of you. Thread hijack, but have you looked into the EI CGR-30 monitor? I think it's a little cheaper, and it MIGHT be able to use the prior EI sensors to save some additional money and install cost. I'm guessing it cannot display fuel tank data, though... Quote Link to comment Share on other sites More sharing options...
Andy95W Posted February 24, 2021 Report Share Posted February 24, 2021 Cliffy- I think I probably have the exact same issue as you, I like the 6 small gauges but my fuel is getting “wonky”. I will be replacing mine with the small Mitchell modular gauges, most of which are PMA’ed for other airplanes. @Sabremech has a 337 Field approval for this modification that I bet he’d share with you. I’m planning to replace my fuel level sending units with the brand new Mitchell ones. I got quotes of $400-600 to overhaul the old style engine gauges, and $150 each to overhaul the sending units from Airparts of Lock Haven. All-in cost of brand new Mitchell gauges and all sending units is about $1100. Mitchell will mark the red/yellow/green arcs on the gauges. @hammdo now owns Sabremech’s airplane and can probably say how well those engine gauges are working after 8 years. Also, @RLCarter installed the same Mitchell modular gauges in his airplane (I’m not sure what basis for approval he used) and wrote about it in the following posts: 1 Quote Link to comment Share on other sites More sharing options...
Skates97 Posted February 24, 2021 Report Share Posted February 24, 2021 On 2/22/2021 at 11:42 PM, cliffy said: Unfortunately I don't have the same gauges shown above. I have the early model that has all the gauges in one block and not individually separable with the 1 screw each so I'll have to send the entire engine instrument block out to fix the fuel level gauges. It does look like they do have a trim screw for setting and maybe AP of LH will have the info I need to trim them in place when they get back. . I think yours is the same as the one I took out of my 65D. It's at home in a box, I can take a look and see if I can get any numbers off it when I get home. The fuel gauges on mine were sticky too, I had to tap them every now and then to get them to work. If you want I could send it to you and you could either send it out for overhaul or stick it in your plane while yours is out to avoid down time. 2 Quote Link to comment Share on other sites More sharing options...
hammdo Posted February 24, 2021 Report Share Posted February 24, 2021 3 hours ago, Andy95W said: Cliffy- I think I probably have the exact same issue as you, I like the 6 small gauges but my fuel is getting “wonky”. I will be replacing mine with the small Mitchell modular gauges, most of which are PMA’ed for other airplanes. @Sabremech has a 337 Field approval for this modification that I bet he’d share with you. I’m planning to replace my fuel level sending units with the brand new Mitchell ones. I got quotes of $400-600 to overhaul the old style engine gauges, and $150 each to overhaul the sending units from Airparts of Lock Haven. All-in cost of brand new Mitchell gauges and all sending units is about $1100. Mitchell will mark the red/yellow/green arcs on the gauges. @hammdo now owns Sabremech’s airplane and can probably say how well those engine gauges are working after 8 years. Also, @RLCarter installed the same Mitchell modular gauges in his airplane (I’m not sure what basis for approval he used) and wrote about it in the following posts: Mitchell's are working great not one issue so far... -Don 1 Quote Link to comment Share on other sites More sharing options...
cliffy Posted February 24, 2021 Author Report Share Posted February 24, 2021 The Mitchells seem good but they don't fit my 6 pac. Skates and I have the same "box" of six NOT individually separable. I'm going to assume that the PO of my airplane put the EI Op/OT gauge in because he had problems with those two on the cluster and blocked them off. I've changed out my transmitters so they are fairly new and now my problem is sticky gauges. I'll check with Keystone tomorrow to see what they can do. Not in a real big hurry so back up gauges won't be needed but the offers were real nice to hear Thanks!!! Quote Link to comment Share on other sites More sharing options...
Hector Posted February 25, 2021 Report Share Posted February 25, 2021 Hopefully this'll help as it sounds like we have the same cluster. As-removed from my 1968 G at last annual, replaced with an EDM900. EDM 900 pic included to show that it's a near-perfect fit where the original cluster goes. All gauges were working when removed and I plan on listing the whole set for sale along with the working as-removed fuel pressure/manifold pressure gauge. Engine is a Lycoming O-360-A1D, 26 gal tanks. The individual fuel gauges have different part numbers and different electrical connections as one is male, one is female (see pics). If you want to verify part numbers, the individual gauges can be easily removed from the front by unscrewing the single screw holding it until the screw is loose, then pull on the screw itself to slide out the instrument. The left fuel gauge shows a stamped date of Mar 6 1968, with an additional stamped date of Oct 11 2002 which I assume is a rebuilt/refurbished? date. The right fuel gauge has a handwritten sticker on it covering the original stamps and I know not what it means.Well....I may be interested in your cluster. My two fuel gages were not working great so I sent them to Air Parts of Lock Haven for overhaul. I was quoted $250 each and paid an extra $75 for expedite. Final bill was $1012 after they replaced the bezels at $150 each and I paid another $62 for overnight shipping to Florida. I was a bit annoyed that I was not informed about the the parts they replaced but water under the bridge and I just wanted ny fuel gauges back. They were shipped overnight last Thursday via FEDEX and no one knows where they are. FEDEX is looking for them and I have a case number opened but so far no luck. After paying $1000 for these damn gauges I may not ever see them again. I’m not even sure what recourse I have at the moment with Air Parts of Lock Haven or FEDEX. Regardless looks like I’m out two fuel gauges and my 67C is grounded until I come up with replacements. Sent from my iPad using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Nokomis449 Posted February 25, 2021 Report Share Posted February 25, 2021 8 hours ago, Hector said: Well....I may be interested in your cluster. Sent from my iPad using Tapatalk Sounds like everything from engines to instruments are being lost in shipping these days. I'll send you a PM. Quote Link to comment Share on other sites More sharing options...
