M20F lower exhaust fell off. In flight
*Members that donate $10 or more do not see advertisements*
I replaced my C's exhaust with one from Knisley. Here is the page on their "modified" exhaust. I'm not sure how 'modified' it is, but I'm sure they can tell you if it fits.
Aircraft Exhaust also has one listed, similarly calling it a 'conversion'.
Did it make a noise when it jettisoned off?
Perhaps you have them already, but It looks like you're also going to need the exhaust hanger bracket and clamp. LASAR has the SB version of the exhaust hangar, here.
Best of luck!
Edited by smwash02
Link to post
Share on other sites
Knisley repaired the exhaust tube on my C a few years ago when the seam in the tube started to split.  By reusing the flange it was classified as a repair, not a new part.  Send them your flange and it will be better than new.
Any MSC can sell you the hardware, tube clamp, and exhaust hangar springs (or did you have a belt style hangar?).  Loewen Mooney Salvage might have what you need, including the exhaust tube, if you want to go that route.
https://www.loewensmooneysalvage.com/
Link to post
Curious to know ...
what  did it sound like?
was this in cruise  ?
How long were you aloft after the tail pipe gave way?
Did the EGT'S go way up?
I am glad you made it down safe.
you want to try Alan Fox or possibly  Lowen  salvage I don't  if this still valid 707.263.0472, Discount Aircraft Salvage  (509) 276-2849.
Sorry for all the questions but I think it is great when people are willing shared the information and experiences  it makes  us all better pilots,mechanics ,....
Thanks,
James '67C
Link to post
For me, I didn't notice any change with temps or noise. I didn't even realize it was missing until I did my post landing walkaround.
My tail pipe was not completely gone as it broke right at the bottom of lower cowling so it was likely still doing it's job to a large degree.
Link to post
After the exit of the muffler, it will be challenging to notice any difference...
The noise has been muffled...
The exhaust pressure has been dropped...
You might get some rattling from a loose pipe in the wind...
Link to post
The duct is poor quality work , use finished ends and smooth lined clamp
This is why I use Titanium in my exhaust builds per sample as 321 does not last
1/3 the weight ,Ti is used on all turbine exhaust apllications
Link to post
@GEE-BEE - what is the paperwork involved in a Ti exhaust? Just as sign-off as "made from better than original" or will my IA need some convincing? Can you share a rough cost for a TSIO-360-LB1 (M20K, stock)? Looks shiny!
Link to post
It was made per sample
Beech Bonanza tailpipes 475.00 pair with hardware.
The e185/e225 model are 304 and are 275.00 pair
the is the notch and angle cut to keep from burning the airframe and correct sound we all want.
I will mfg headers next for Bonanza
Iam working on my new design exhaust stacks in titanium for my tbm700.
GB
Link to post
Some tail pipes need some expert help...
There are some Power Flow exhausts that got the tail pipe designed for something else...  when applied to the Mooney, they stick out into the wind...
Kind of defeats the purpose of the PF exhaust... :)
There are a few Mooneys where the tail pipe just disintegrates over the decades... starting at the weld at the open end...  probably a weather/environmental challenge, partly...
If you have pics of Ti tail pipes for O/IO360s and IO550s.... that would be extra interesting...
Link to post
Are you able to stretch the end of the tube to fit over a larger tube?
Link to post
Guy,
Do you see anything on the horizon to improve on the single-use V-band clamps used on turbo exhausts?
That first section of pipe in turbos is under pressure, and very hot...
The erosion on the pipes is relatively high, leading to pipe thinning over the years...
We have had some owners report wall thicknesses so thin they could poke a tool through it easily...
We have had owners not know their v-bands were getting torqued more than recommended...
Exhaust leaks before the turbo can be very dangerous... from CO leaks to cutting torches...
It would be interesting if Ti or changes in clamps can improve maintenance for turbo owners...
Link to post
22 hours ago, GEE-BEE said:
We design tube to slide next to muffler bead per oem.
Clamp secures bead to Bead
I’m thinking these would be nice on my Comanche 400.  The current tailpipe has the upper end stretched to fit over the exit pipe of the muffler.  The clamp has a pin which locks them together, not the beaded clamp design of the Beech
Link to post
On 2/15/2021 at 7:05 PM, carusoam said:
Guy,
That would be a thicker wall thickness or 304 or Titanium
the clamp mfg is Marman / aeroquip
Remember , TI is 1/3 the weight
vibration and weight is the problem and thin wall thickness.
I made new cnc exhaust mount brackets from stainless steel, my hangers are three times thicker spring steel , followed by lighter titanium tailpipes, the angle cut keeps exhaust stains and the sound note that was a oem design, but all aftermarket exhaust do not cut to original spec .
Iam doing some stacks and my dream is a five blade prop from MT or Dowty
I might mod my fuel control and fuel pump for added power ,Temperatures would have to be addressed depending on torque and altitude.
PT6 talk here , sorry
GB
Link to post
