A real nasty icing signature!
25 minutes ago, GeeBee said:
Many years back I got to associate with some guys from Aeroflot. One thing the Russians say "Nyet" to is freezing rain. They don't operate in it. That should be a clue as they are some of the greatest cold weather operators in the world.
I guess airframe icing is not an issue past -40C or -80F and dry continental climate
But could be problematic for engine fuel & oil and pilot bones :lol:
https://www.euronews.com/2021/01/14/region-in-siberia-has-longest-cold-spell-for-14-years
Link to comment
Share on other sites
Freezing rain is bad news, but have you ever seen anything made in Russia that is reliable?  Soyuz rockets have 25 engines for redundancy.  I have seen video of launches where you can see at least 3-4 not functioning.
Link to comment
While I am not a fan of Soviet tech, they did launch the 1st artificial satellite, only then the US stepped up their game. And one could argue that a successful launch with 1/6 of the engines not running is a win. :)
Link to comment
Yes. Kalashinikov. Ask your ground pounders which they would rather have. AK-47 or M-16.
I own the semi auto versions of both by the way. One looks like it is made with a wood rasp and functions perfectly. I have never, ever cleaned it.  The AR-15 requires constant cleaning to function properly.
Link to comment
On 2/11/2021 at 10:59 AM, HXG said:
Here’s a NWS  link including SkewTLogP icing signatures:
https://www.weather.gov/jetstream/skewt_samples
Keep in mind that the freezing rain signature they show here only accounts for about 8% of the cases.  It’s the exception, not the rule.  While the signature they point out is dangerous for pilots, the nonclassical case is the one that tends to not be well understood by pilots.  In fact, the entire temperature profile can be below freezing and still produce freezing rain or more likely freezing drizzle.  Also what is said about sleet (below) is not entirely accurate.  The snowflake only partially melts and retains a slushy core. The retained core is what allows the partially melted drop to refreeze.  Without that core (complete melting), the air must be extremely cold for it to "refreeze" into a pellet.  Sleet is a very important indicator of SLD aloft.
"As snow falls into the 'warm nose', it melts into a liquid drop/rain. Then the liquid drops fall back into the arctic air mass (near the ground) that is cold enough and deep enough for the liquid to freeze into ice pellets before reaching the ground.”
For another explanation, you can read my blog here on precipitation types.
Edited by Scott Dennstaedt
Link to comment
On 2/7/2021 at 5:45 AM, mike_elliott said:
Scott was on the agenda for the Summit VIII we postponed, perhaps @Seth has him back on. I know Seth is busy putting this Summit together as the reins pass to the younger gen of Mooney pilots and will soon have the agenda up.
I will have the agenda out soon!
-Seth
Link to comment
It certainly explains why the worst icing I ever experienced was after the sun went down on freezing rain and it turned to snow. It was in a Mad Dog (aka "the popsicle") and it was not fun.
Link to comment
